Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 3rd December 2006
dagsportster's Avatar
dagsportster dagsportster is offline
dagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the roughdagsportster is a jewel in the rough
Default Does Avon mark the light spot on their tires?
I got an Avon Venom front tire and I'll be damned if I can find the light spot marked any where. It's a whitewall, so it's got the blue film on the stripe, and that blue stuff is put on a little sloppily as it's meant to come right off. Maybe the stuff wore off, but I'd be curious to hear from others who've mounted Avon tires how they mark 'em. Thanks.
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Can you enlighten us on the "light spot" more? you talking about the balance point? they are quality tires made
in the U.K. that don't need it.
BTW- the blue film is to protect the white wall from getting scuffed or chaffed during shipment, it comes right off.
RTFS
Ride That F'N Sportster!!
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to beholdJimbos883 is a splendid one to behold
Generally on automative tires the manufacture puts a dot on the sidewall of the tire indicating the lightest point in the tire. It's for helping in balancing of the wheel and tire. The tech's are suppose to mount the tire with that dot in the area of the valve stem. At least that's what I've been told.
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
XLFREAK XLFREAK is offline
correct. not all tires have them due to quality. the really good ones are balance internally and not needed. the really cheap ones are not marked cause they are to cheap to do this. the average michelin, goodyear, yokohama... will be marked
xllent01's Avatar
Cheap? who you calling cheap i wouldn't say Avons are cheap.
But if your calling me cheap thats ok.
XLLent01 -- I never know when you're being serious Yes, light-spot = balance point. Lazy mounters will put the light spot of the tire aligned with the valve stem (usually the heavyest side of the wheel) and call the tire balanced.
On my new wheel, the wheel is 1 oz light at the valve stem hole (but since it's a tubed tire, that will change when the tube goes in).
Finally, I did find this elsewhere --- apparently, Avon does NOT mark their tires' light spots (balance points)...
http://www.dansmc.com/balancemark.htm
i also sayed the really good ones arent marked either
Old 4th December 2006
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
The valve stem isn't always the heaviest spot............
The heavy spot on my rear (with the valve stem installed) is about 10 degrees away.. never bothered figuring out the front because it has a tube; I just assume the valve is the heavy spot.
Ed
The Only Y2K dual-set 883C
So Cal
