Last Post: conv90
Last Post: groovemeisterus
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Old 28th November 2004
sportydan sportydan is offline
sportydan has disabled reputation
Default Removing carb
I want to remove carb off of 05 883C.I have the HD service manual.I understand most of the removal process.The part I don't understand is removing the throttle cables.Manual just says to remove them.Once I get everything else disconnected do I pull carb out far enough to take cables off or is there something else I need to do.I had the dealer do the tax thing.But I'm getting a lot of spitting & sputtering when I first take off from a stop.Also when cruising I'll get a pop thru the carb once in awhile.I want to take carb apart and see just what he did to it.It has a Yost kit in it.He used the blue needle,installed a #165 main (original was #175) think he installed a #45 slow,because there's a #42 in bag.Other than that I don't know what he did.Also plugs are white indicating a lean condition.This I don't understand why.Any help on this matter would be greatly appreciated.
Chuck's Avatar
Chuck Chuck is offline
Sportster/Buell Year: 03
Other Motorcycle Model: Elecectra Glide Classic
Other Motorcycle Year: 2010
Chuck is an unknown quantity at this point
I can't remember if I had the cables off. I remember loosening them is all.
I would bring it back to who did the work, myself. That's part of the reason you have somebody else do it, to eliminate some headaches. If you do pull the carb you should probalbly replace the rubber seal. That could even be your problem. When you put the new one on, rub a little dish soap around it to let her slide on nice.
Good luck.
2010 FLHTC
daPainta's Avatar
daPainta daPainta is offline
daPainta is an unknown quantity at this point
Put cables off is really simple when the carb is fully away from the manifold. Just hang them out (this round ends)
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
TAKE BIKE BACK TO STEALER FIRST THING MONDAY MORNING
ask friendly service guy about the jetting being wrong
and before you make a scene if they will fix it for free.
Any good stealer who wants to keep loyal customers will take it right in and get it fixed for you.
Take advantage of the stealers dyno machine, the dyno will get the
jetting right on the money. Any idot tech will read the directions
off the back of a box and then tell you that the jetting is just fine.
THE DYNO IS A TUNERS BEST FRIEND
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
I agree with xllent01, if the dealer didn't get it right, then he should fix it, and most will be glad to do it if you ask. Chances are that you really do not have to remove the carb at all. MAybe just a slight adjustment to the idle mixture is all that is required. On an 883 with that needle, I wouldn't have installed the 45 slow jet though! If it were me, I'd have left the 42 slow jet, re-tuned the idle mixture, installed the blue needle and tuned it's height and would be running a 165 or 170 main.
However, if you really want to pull the carb off the bike, I find the easiest way and least stressful to the cables is to pull the carb, and then remove the throttle cable bracket from the carb top and side of the carb (two screws).
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Similar Threads
Exhaust leak = Carb farts? DM-SC Sportster Motorcycle General Discussion and Problems 3 15th May 2005 01:29
Pop mixture plug with carb on bike??? Sportster Girl Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 8 14th May 2005 00:55
Carb fart question NYJETS Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 4 10th May 2005 05:17
Carb rebuild Dan S Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 13 8th December 2004 18:57
