Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
0 Ironhead 2 into 1 exhaust?
Last Post: Iron John
Old 13th February 2009
DIESEL's Avatar
DIESEL DIESEL is offline
Default I screwed up and need help
I ordered the wrong part from Zanotti's for the wife's bike. I sent them an email and don't know if they will take it back since it is electrical. I ordered the module that goes under the battery, not the turn/run/ module that plugs in.
I got the Nightster license plate assembly with the light for the plate. I chopped the fender, no more brake light, and I got dual filiment guts for the turn signals three wires each.
Can someone please tell me, like I am a 3rd grader what part I need to get from harley so I can make this work like the nightster rear end? I have no problem wiring the damn thing, I just need a simple explanation, so that the turn signals work as brake lights, running lights, and turn signals, and how to hook up the light for the plate.
I have searched several times, and just really need some help, thank you in advance.
DIESEL's Avatar
Since I have dual elements for the turn signals, couldn't I just do some splicing and make it work without a turn/run module? Basically run the the wires the originally went to the tail lamp to one of the lamps on the dual element turn signals?
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
on older cars that use 1 dual filament lamp per side, one filament is used for run only, the other filament is a shared brake/ turn light...... I don't know off hand how to wire it up like you want but I would just spend a few minutes with a test light and figure it out.
Ww
master wizard
[B][COLOR="Red"]Super Moderator[/COLOR][/B]
[FONT="Book Antiqua"][B][U]RIP Mr Jimi[/U][/B][/FONT]
"All The Way"
Spadesluck's Avatar
Spadesluck Spadesluck is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 1991
Spadesluck is on a distinguished roadSpadesluck is on a distinguished road
For brake and running lights you can run the right along with the brake light. They can all share the same ground and the other 2 wires will be the hots for running light and brake light. For the turn signal just use the stock wire to make it flash. You will have four wire coming of the signal lights, 3 hots and a ground.
If you want your license plate to be on al the time just wire it into the the running lights.
Having a test light will help you out a lot.
capttawes's Avatar
capttawes capttawes is offline
capttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished road
This might help... http://sportster.org/blog/how-to-ins...our-sportster/ just read down to the wiring part.
Matt
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
I though there was one in the classified(nightster light module)
In three words I can sum up everything I've learned about life: it goes on.
snowman's Avatar
snowman snowman is offline
John at Zanotti's is very good with getting the right part numbers. If you don't get an answer back, maybe give him a call and tell him what happened. If you didn't tear up the package or the module, he may let you just send it back for the right one...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
honkytnkmn's Avatar
honkytnkmn honkytnkmn is offline
Sportster/Buell Model: Sportster XL883
Other Motorcycle Model: Ferguson TO-30 Tractor
Other Motorcycle Year: 1953
honkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the roughhonkytnkmn is a jewel in the rough
Diesel,
I did this mod to my bike last year, I don't remember what wires go where, but I had the brake/turn module and swapped my duel filaments from my front signals. It took me a while, but I figured out the wireing to make the duel filament signals work with break/run/turn. I'm pretty sure I posted a thread or at least added to a thread here.
But it can be done with the brake/turn module.
2007 XL883, V&H SSS, Screamin Eagle A/C, PCIII, Chopped Fender, Chopped Cam Cover, Drag bars 6 1/2 Risers.
John03XL883's Avatar
John03XL883 John03XL883 is offline
Sportster/Buell Model: xlh 883
John03XL883 is on a distinguished roadJohn03XL883 is on a distinguished roadJohn03XL883 is on a distinguished road
Yes you can just get a light tester and go at it should'nt take long at all
[SIGPIC][/SIGPIC]Drive it like you stole it
DIESEL's Avatar
I ordered the module for the nightster. Since I have the same equipment it should be plug and play. Zanotti's is also going to allow me to return the part, minus 20 percent, but in the end it will done right.
