0 Rear wheel offset?
Last Post: Pitzky
0 Question about our school systems
0 Ran out of gas.
Last Post: Sportster25
0 Seneca Shadows WV. Sept. 5th to 8th and maybe beyond.
Last Post: XL Ed
0 Keihin carb…mixture screw
Last Post: Darren Rahilly
0 Major update forthcoming
Last Post: xena
0 Hello from Cape Cod
Last Post: xena
0 New to Harleys
Last Post: Dusz
0 1983 Ironhead! No Spark
0 What engine oil do you use?
0 Turn signals won't work when cold
Last Post: Debute23
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
5 Not charging, new Reg w/weird readings
Last Post: spoon
0 Turned down by a Tattoo Artist
Last Post: Deimus
0 Does Yankee Engineuity still exist?
Last Post: ReddTigger
0 The adventure of bringing my Sporty from Italy to Denmark
0 Cams for Alcohol (E85-E98)
Last Post: delcrossv
0 Front end assembly questions
Last Post: Kit352
PlanB, Cuco6924 (77), 1200sporty (66), iron68 (52), LifesHarlequin (39), mattosm (38)
Old 3rd December 2006
XL Custom 1200 XL Custom 1200 is offline
Sportster/Buell Model: 1200 sportster XL Custom
XL Custom 1200 is on a distinguished roadXL Custom 1200 is on a distinguished road
Default Recieved wrong big sucker parts in box...ARGH !!!
Well, I went to install my big sucker, only to find out that first of all my gasket wasnt right, then that my backing plate wasnt right either
When you put it up to the carb, the plate does not go up against the carb body and seal. It has about a 1/16th to 3 /32 gap. The box says for my model sportster ( 18-803) but the backing plate has a part # of 18-492-1 if that is suppose to be the same??? So now I am stuck with my stuff off and really dont want to put back on the SE A/C as a temp. So I guess I just need to call Arlen Ness and find out what needs to be done
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
Maybe it's not a Big Sucker Air Cleaner. It's a Air Cleaner, BIG SUCKER.
If the weathers good enough to ride, I'd just put the SE back on.
Old 4th December 2006
OK, I jumped to conclusions I guess. The backing plate did work finally after talking with the Ness guys. He said that maybe my carb was pushed back on the rubber flange a bit. So what I did was just bolt it up to the carb and tightened on the screws and it came together. As for the gasket, he said try flipping it over, and seeing if they line up. But the instructions said to stick it to the carb, and his way would have had me sticking to the backplate, which looked like that might have worked, but I had already modified the gasket and stuck it on the carb. It worked, no worries. Thanks for the response anyway !!
Now Im running lean again, LOL...back to the drop idle I guess, LOL
