0 too bad
Last Post: Hank21113
0 Head gaskets.
0 Dynamic timing the 2000i?
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 blonde, brunette, red?
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
0 Nighster seat on Iron
Last Post: ed_in_az
Last Post: lo-rider
0 where are the pics?
Old 7th December 2006
Aldra's Avatar
Aldra Aldra is offline
Aldra is an unknown quantity at this point
Default Broken 4th gear
I already mentioned it in an other thread. But I wanted to put it in here and also wanted to ask if anybody else had this problem in the past.
My XLH1200 1994 - lost the 4th gear. While I was riding in the 4th gear it jumped our suddenly. When I tryed again to put it, I was in the neutral. Changing to the next gear I had the 5th one. I tryed carefully to go through all the gears, and could do it without any problems. 1, 2, 3, neutral 5th. Well, it was clear there is a big problem. As I heard no specially noise comming from the transmission (with the Screamin Eagle II I nevver heard some noise from the engine) I decide to drive home carefully. In the garage I began to take a way the primary case and I already saw the pices. Finally I pulled out the gearbox and saw that the shifter fork for the 4th gear and the gearsprocket 1st gear was broken. Well I already ordered them and still waiting to get it and to fix it.
On my page under vvv.drapela.ch/GETRIEBE (you will have to change the "v" against "w". It doesn't work otherwise) you can see how it was.
I will tell you when its finished.
Ciao ALex
[B]The Best PART of Any Bike - The One That Rides It.[/B]
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to beholdJason's Sporty is a splendid one to behold
any pictures? I have a few up from when I lunched the main shaft and sprocket on my 86 but that was last year,I have no idea where the post is.
Aldra's Avatar
the pictures are under drapela.ch/GETRIEBE
by
