0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 8th December 2006
redhouse's Avatar
redhouse redhouse is offline
Sportster/Buell Model: sportster 883 xl
redhouse has disabled reputation
Default carb jets for new pipes...
anybody out there know what size jets i need to upgrade to for vance and hines short shots? i have a brand new sportster 883xl.
shotgun46's Avatar
new guy eh ! well welcome to the group ! did ya read jetting 101 in here?
http://www.harley-performance.com/ha...arburetor.html also look here http://www.sportster.org/tech/carb/rejetting.shtml good luck lets us know if ya need more helpyou do not have remove the carb to re jet ! you can do it just by removing the carb bottom ! (bowl)Find the four brass screws that hold the bowl on the carb. Using a phillips screwdriver that completely fills the slots in the screws remove them without letting the screwdriver slip and damage the screws. This may take considerable pressure. When removing the screws, hold the bowl in position until they are all out then pull the bowl off straight down. Be extremely careful... the floats are just inside the bowl. The rod will come out of the bellows and hit against the carb body... no you didn't drop it. Set the bowl (with dangling drain hose) aside some place clean. Note the brass tube on it that was sticking up in the carb mouth.nextLooking at the bottom of the carb, find the two jets. The main jet will be more or less in the middle, screwed into the emulsion tube and should say "160" on it for an 883, "170" on it for a 1200, or 190 on it for a Sport or International model. The emulsion tube will have flats on it for a 5/16" wrench. Hold the emulsion tube from turning with the wrench and using a common (flat) blade screwdriver that's wide enough to fill the slots on both sides of the main jet, unscrew the jet (counterclockwise).nextFind the slow jet on the carb bottom. It should say "42" on it and you'll replace it with a #45. It will be down in a tube cast into the carb body. You must find a screwdriver with a blade wide enough to fill the slots in the jet that doesn't taper wider above its tip, or it won't fit down into the tube to reach the jet. You may have to have a machine shop grind a screwdriver down so that it's shaft is no wider than the blade at the tip. Do not try to force an inappropriate screwdriver in or you will crack the cast carb body. Unscrew (counterclockwise) the #42 slow jet and replace it with a #45 slow jet. Tighten firmly, but do not strip. Do not use LockTite.this is only a starting point your slow / main jet size may vary
Sportsters Rule ! :banana
rikava rikava is offline
rikava has disabled reputation
I'm running '02, 883C with SE slip-ons and I'm running stock jets. Haven't really seen the need yet and I put 15,000 a year on my bike.
You said you have a new 883.... I was under the impression that they weren't carburated anymore.
shotgun46's Avatar
its an o6 model !
redhouse's Avatar
thanks guys,
no i have a 2006. bought it brand new off the showroom floor november 30th this year. the 07's are injected.
redhouse's Avatar
here's me and the bike with brand new vance and hines short shot staggered pipes.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
You could just get one of these:
Folkie
South East England Riders
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Hey cool bike and shop. Are you an airbrush artist? It looks it from your avatar. Do you have some examples of your stuff?
Old 9th December 2006
redhouse's Avatar
i do...but apperently i'm not allowed to promote myself or business without paying. so needless to say i can't give out my website or tell you anything about my business without someone else getting a piece of it.....SORRY
[B][FONT="Arial Black"]cool's the rule and it costs to be cool. [/FONT][/B][FONT="Impact"]
DieHard's Avatar
DieHard DieHard is offline
Sportster/Buell Model: XL 883L
DieHard is on a distinguished roadDieHard is on a distinguished road
my 06 883 i'm running a 45 slow and a 180 main and 2 turns out on air/fuel mixture screw with se a/c and cycle shack slash cut exhaust. runs great.
