Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Accessories
0 strange small wires attached to coil
0 24633-77 Breather assembly
Last Post: ericfreeman
5 Transmission HELP!
Last Post: Twistedrench
0 Sportster or Street Bob
Last Post: Baby883
0 Ei
Last Post: tvon
0 Solar battery charging
Last Post: tvon
Last Post: wachuko
0 primary chain temp.
0 2016 48 Hesitating
Last Post: XLXR
Last Post: prahxy
Last Post: hhugger
2003, bolt, passenger, pegs, xlh
Old 17th February 2009
otistheaxe otistheaxe is offline
otistheaxe is an unknown quantity at this point
Question Passenger Peg solutions 2003 XLH
Okay, so I just got my first Harley a few weeks ago via sweet trade. I am trying to customize it and finding that, so far, 95% of what I buy for an "84-03 Sportster" doesn't exactly fit without some work. My most recent problem are the set of passenger pegs made by Harley Davidson. I get the mount on there fine with the 45 degree angle and all, but the right side mount is about 1/8" away from the pipe and rotating the passenger peg up and down will destroy the pipe. I'm a little bit more confused about this just because it's an actual Harley part that I'm trying to put on here. Are there any solutions for this? I am looking at possibly buying a Kuryakyn offset mount, but I can't find specifically if the bolt will fit in the passenger mounts. The ad says it will fit any 1/2" -13. Is this the size of the passenger mounting hole for a 2003 sportster XLH? Thanks in advance.
gamhill gamhill is offline
gamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura about
I've got the H-D brand O ring style on mine. Bolt on, No issues. I do have a 2-1 pipe, but even when I had the stock pipes I don't recall an issue.
What pipes are do you have?
I have the stock pipes. I can get it bolted on and even install the pegs, but rotating it comes in contact with the pipes. It wont let me post a URL because I haven't made enough posts yet, but the HD part number is 49105-83. I believe they're the same as your O-Rings, just rubber (which doesn't really make a difference for the problem I'm having).
The bike is still at stock height (no aftermarket shocks).
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
Can you adjust the pipes downward enough to so the peg clears it.
ReddTigger's Avatar
your shocks may be worn out.. That's one idea.
another is that the exhaust is angled up a little too much in the rear.
Something doesn't sound right. I have mine rotated at a 45° angle and no problems.
States I've Ridden in
71.3 hp 70.8 tq
darth's Avatar
darth darth is offline
Sportster/Buell Model #2: 1200 Custom
darth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant futuredarth has a brilliant future
You can gain some clearance by loosening the headers and shifting them just a bit. Also, the taller the shocks, the less clearance you will have.
Darth
2010 XL1200C (Mine)
2009 XL1200C / Champion Trike Kit (Hers)
My Gallery
Ol' Wrench Head of the White Werewolfes MC
