Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 21st February 2009
Curbfeeler's Avatar
Curbfeeler Curbfeeler is offline
Sportster/Buell Model: XLH883
Curbfeeler is on a distinguished roadCurbfeeler is on a distinguished roadCurbfeeler is on a distinguished roadCurbfeeler is on a distinguished road
Default How Does An Air-Shifter Work?
How does an air shifter work on a drag bike?
Does the transmission or clutch need to be modified?
Thanks!
Old 23rd February 2009
chopperdave's Avatar
chopperdave chopperdave is offline
11sec CLUB, MEMBER
Sportster/Buell Model: 1474 (diguised as 883)
Sportster/Buell Year: 94
Sportster/Buell Model #2: 2004 buell xb12ssnc
chopperdave has disabled reputation
Thumbs up
Thanks!
no and no
it has amomentory kill switch.
it works like throttle up and put presure on the shifter, and back off the throtle some the tran will shift out and in next gear(power shifting)
i do it all the time
Old 14th July 2009
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
It can get a little more involved than that, But that works. My buddy has a drag bike and his shifter is a simple button and he never lets off the throttle.
When the button is hit there is a timer that kills the ignition for a milli-second just as the air solenoid fires the air cylinder and pulls the shifter.
Old 14th July 2009
joesporty's Avatar
joesporty joesporty is offline
Sportster/Buell Model: xl 883
Other Motorcycle Model: kz750
Other Motorcycle Year: 1976
joesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant future
sounds about right...has a little pump simular to that on an airhorn...push the shift up botton air pressure moves the actuator moving your shifter shaft at the same time kills the ignition for a split second...no need to let of the throttle..
and yes you can do the same thing with your foot..powershifting...
SMOKEY BURNOUT MASTER OF THE WORLD!!!!!
08 XL883;HAMMER 1250,Heavy breather,Rinehart 2-1, Power Vision,Ebc floating rotor,XR1200 Nissin caliper,1200R Mastery cylinder,RK shocks,1in tank lift,wire tuck,crossroads fork brace,low rise drag bars int.wired,Goodridge Ss line,Chrome valve stem covers, and a few top secret parts..:smoke
