Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 18th March 2005
Nurple's Avatar
Nurple Nurple is offline
Sportster/Buell Model: XL w/ 1200cc conversion
Sportster/Buell Year: 1986
Nurple has disabled reputation
Default 10mm or 12mm banjo
What exactly is being measured at 10 or 12 mm?
Old 18th March 2005
Turbota's Avatar
Turbota Turbota is offline
Any metric bolt you buy is measured at the threads ... A bolt that is sold as a 10mm may have a 14mm head that requires a 14mm wrench to tighten.
04 XL 1222R
Old 18th March 2005
Speedy818's Avatar
Speedy818 Speedy818 is offline
Other Motorcycle Model: VRSCR
Speedy818 is an unknown quantity at this point
OK Ron, does that just apply to metric bolts? what about SAE?
now let's go back to metric bolts, since that's what we're talking about before - is the measurement taken at the edge of the threads, or on the inside? If you measure with a dial caliper the outside of the threads on the bolt, then the inside of the nut, there would be a difference of twice the thread depth, right? That might be outside of the tolerances - which measurement is the right one (or neither).
The reason is: I've got an FXDX braided brake line that I'm going to put on my 1200R - which has a wierd banjo bolt at the master cylinder (I think it's 1/2"/ 12.7mm) If I ream out the banjo fitting to the size of the threads on the bolt, will that be too large?
Speedy
Old 18th March 2005
Turbota's Avatar
I have not read the info in this link, but I believe it will explain everything you want to know about fastener sizes: http://www.boltdepot.com/fastener-in...t.aspx#general
Here is something that costs no more than 5 bucks that is readily available. Seems like you could put it to good use:
Old 18th March 2005
Speedy818's Avatar
This may be the best internet site I've ever found (except for www.xlforum.net)!
Thanks!!!
Speedy
Old 18th March 2005
Nurple's Avatar
Thanks for the input. I think I need to clarify further. I am in the process of looking for all new banjo bolts for the entire brake system. The basket case i picked up did not come with these items. Better yet, the brake system is a combination of parts produced over the past twenty years. So unfortunately, I can't go to good old JP's and order a standard replacement set for an 86 xl.
So, the real reason I asked the question. The front brake line is an OEM off a ~97-99 dyna. The master cylinder end clearly requires a 7/16" banjo bolt with 24 threading. The caliper end requires a 3/8" with 24 threading. So, at which point in the equation is the 10mm or 12mm taken into consideration?
The only thing I can figure, is that the thickness of the Banjo fitting is 10 or 12 mm. I say that because when I hold the two ends side by side the caliper end is thicker than the master cylinder side.
Old 18th March 2005
Turbota's Avatar
Nurple .... I wish I could be of some help, but I'm not sharp enough with the problems your faced with ...
Maybe someone one else here could lead you down the right path.
Old 18th March 2005
AeroSport's Avatar
AeroSport AeroSport is offline
Sportster/Buell Model: 1200 XL Roadster
Sportster/Buell Model #2: 8830XL
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XLS Roadster
Other Motorcycle Year: 1980
AeroSport has disabled reputation
Nurple... The 10mm or 12mm refers to the size of the Banjo fitting opening. The bolts themselves can be metric or SAE. Metric size banjo bolts have 2 thread pitches 1.00 and 1.25 mm. the SAE is usually 3/8" x 24 threads. New HD's use Metric thread Banjo bolts but I'm not sure what thread pitch. Hope this helps
:sporty:
[B]2007 1200XL R [/B] :tour
[I]RB Racing 2:1/ Mini Max/Power Vision / Dyna FXDX cartridge forks/13.5" Ricor IAS /Willwood/EBC front brakes/Lyndall Metal Matrix rear and much more[/I] :usaflag
Old 21st March 2005
neckball neckball is offline
neckball is an unknown quantity at this point
FWIW, a 10mm banjo and a 3/8" banjo are one in the same. Some of the aftermarket performance plumbing company's (Earl's, for instance) will have two part numbers but the banjo is the same. The difference will be in the banjo bolt.
Old 21st March 2005
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
just to add to this..... HD uses 2 bajo bolt sizes...
a 10 and a 12... one is for twin disc master cyls and the other for singles....and I can't remember which is which off the top of my head...
the 10mm and 12mm refers to the major or outside diameter....
a 10mm or 12mm banjo bolt or washer refers to the inside diameter or hole of the banjo bolt or washer
Similar Threads
What size banjo bolts? PSEBYL Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 9 24th April 2005 02:03
Banjo and bolts coming loose chaserband Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 6 8th March 2005 03:34
