0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 Stage 1 results
0 Screw Loose's Repairs
0 C.O.B.B run west
0 Lowboy frame conversion
Last Post: Sportster-92
0 Spokes or Mags
0 Project of the day
Last Post: Baby883
Last Post: kaveebee
Old 25th February 2009
Richard D Richard D is offline
Sportster/Buell Model: 1977 XLH Rigid
Richard D is on a distinguished roadRichard D is on a distinguished road
Default Horsepower and Weight Specs
Quoting from here:
http://www.sportster.org/history/index.shtml#1953
"1972:
The 61 cid (called a 1000cc) XL replaced the 900.
Rated for 61 hp, 9:1 CR, 110+mph, 13.38 sec ¼ mile (97.7 mph), and 43 mpg. Bendix/Zenith carb.
Wet clutch.
New oil pump.
Oil tank placed near chain
Seat is thinner w/less padding.
Production Information:
XLH (7,500) $2,120
XLCH (10,650) "
That was the last entry before '77(my year) that listed horsepower, I assume it didn't go down.
I also remember reading smewhere that
"all Sportsters weigh less than 500lbs."
Do these figures sound accurate? What would the weight reduction be with a weld-on hard tail?
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
my 72 is a small bike, its still the 900 frame, just a 1000 engine. so it might be lighter than 73 and its heavier frontend.
but different models have different weights in any given year.
HP should be about the same through the 70's
"lord of the Night Lite"
thank god for darwin ;)
dwint's Avatar
dwint dwint is offline
dwint is on a distinguished roaddwint is on a distinguished road
when i took my 72 to my machinist (he was in his early 60's)i told him i should have 61 hores.he started to laugh saying back then they did'nt have accurate dyno's and i bet you don't have more then 45 horses.with 10to1 -40 over and drags it was 46 rwhp.so he told me of his friend down the street would get some more h.p out of it.well when i went to pick it up the dyno showed 56 rwhp.so he got me 10 more horses.i asked what did you do to get so much more.he adjusted the carb and put 1/4 inch bolts threw the drags.i could'nt believe 56 hp had so much power,so i figured i would try the bolts in my wifes 95 1200 with drags and it whistled like crazy.i looked at mine and noticed the dyno guy grinded off the threads so i did the same and no more whistle.it's funny how the old timers no these little tricks.
I forgot to add I read the same thing, on page 100:
http://books.google.com/books?id=cM9...um=6&ct=result
jagdprcp's Avatar
jagdprcp jagdprcp is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1979
jagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enough
The first spec was horsepower at the crank. Your primary, transmission and final drive all play in to figuring RWHP but would account for only having 46HP at the rear wheel (RWHP.) The only way to know what your bike weighs is to take it somewere and have it weighed.
Skeeeter
'76 XLH - 4 5/8" Stroker, Andrews V-9 cams, S&S Super 'E' and Barnett Billet Scorpion Clutch plus some cosmetic stuff
'79 XLH - Mostly stock except for cosmetics (for now!)
Old 26th February 2009
As far as weight, what's a rough estimate? A stock Sporty, under 500lbs?
dwint's Avatar
my 72 was 472 pounds
SirAsh's Avatar
SirAsh SirAsh is offline
Sportster/Buell Year: 1979
Other Motorcycle Model: fxstc
SirAsh will become famous soon enoughSirAsh will become famous soon enoughSirAsh will become famous soon enoughSirAsh will become famous soon enoughSirAsh will become famous soon enoughSirAsh will become famous soon enoughSirAsh will become famous soon enough
my 79 hd service manual says as shipped from the factory xlh-522lbs xlch-513lbs
