Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding with disability
Riding with disability Discussions on how to ride with minor or major disabilities.
Last Post: FiftySixer
0 900cc Cylinders
Last Post: Staffords
0 Hagerty Insurance
Last Post: Akdawg
Last Post: XL1275
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 wavers
Last Post: ZCarFan
0 tachometer on 2012 Custom
Last Post: The Doctor71
Last Post: XL1275
0 Early Sportster Shock Absorber Disassembly
Last Post: Heff
0 New from Michigan
Last Post: 1skullster1
0 Fuel Sputter & Much More
0 Another Ohio Meet & Eat?
0 Rear wheel alignment
0 low rpm problem
0 Help Identifying Pistons
Old 26th February 2009
Kent's Avatar
Kent Kent is offline
Kent is on a distinguished roadKent is on a distinguished roadKent is on a distinguished roadKent is on a distinguished road
Default Compressed Disk
Been having some pretty bad pain lately.
Can't sit on the bike for more than about 20 minutes.
Doc says I have a compressed disk between S1 and L5 that is also pinching some nerves. Apparently I've had this for years (possible from a bike wreck about 13 years ago) and it finally degenerated to the point that the pain kicked in.
Bike setup is 11.5" progressives and the old stock seat.
Been looking at a more comfortable seat anyway. Think I'll have to ditch the shocks and go back to standard height? Or is the old Sportster a little too much for it?
I'm currently seeing a chiropractor and doing some PT to try and get things back in order.
Anyone with a similar experience, never really had a back issue before so not familiar with this.
Old 27th February 2009
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
I think I know whereof you speak, Kent.
My L5 disc is "desiccated" according to my orthopedist. From a 30 year old bike wreck, it is shriveled up and gone. In an MRI it's just a black void where the disc should be.
From physical therapy I got a stretch routine that keeps me going. Most of the time it doesn't hurt bad at all. Today is not a good day though.
Anyway, what I do is back stretches laying flat on my stomach I alternate 1 min flat, then 1 min lifting up on my elbows arching my back at the point of L5. I do this a couple of times, then switch to lifting by putting my hands down instead of the elbows. Don't lift too high, just a bit higher than the elbow lift level. I do a couple of each and not all that often either, just when it hurts bad. I did my 3 ibuprofen today and the stretches already. I musta pissed off my back somehow today. I guess I moved wrong.
Good luck, and if your physical therpaist hasn't had you try this routine ask him/her about it.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
arab1302's Avatar
arab1302 arab1302 is offline
arab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rougharab1302 is a jewel in the rough
Originally Posted by Kent View Post
I'm currently seeing a chiropractor...
Best thing you can do. I have a herniated disc between L5 and S1. Just about the time that the sciatic pain dissipated and I was getting back to normal, I reinjured it doing something stupid. I started seeing a chiropracter and it was not long at all for the pain to leave.
I have never been happier with any other medical decision I have ever made.
rontech rontech is offline
rontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished road
I don't have a herniated disk but I did have a motorcycle accident in '95. I injured my back bad enough to keep me out of work for 2 years. I returned to the work force in '97, only to re injure it after 1 1/2 years. In '99 i returned to work, and the back was getting progressively worse.
Between '95 and 2004 I have seen 10 doctors and had 4 MRI's. Finally, the last Dr. said I have spinal stenosis, along with a bulged disk at L4-S1. In '04 he sent me to a neurosurgeon, had surgery done, no more pain. I still watch what I do with my back though.
I would like to customize my sporty like my old ironhead was, however I don't think I could do a hardtail. So I'm going to figure out how to make it a softail using the stock frame.
95 sporty 95 sporty is offline
Sportster/Buell Model: xl
Sportster/Buell Year: 95
95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough95 sporty will become famous soon enough
Look into decompression.I walk my dog 1 hour a day and there is a 4" pipe gate that crosses a levy to blockcars from a set of railroad tracks on the route.I started hanging over it at my waist using my legs as a counterbalance.This allowed me to stretch my low back hanging upside down and I could really feel the tender area that has caused me pain since the 80's.I then bought a Teeter Hangups Dex II which is a decompression device where you hang from the waist area.They have ones where you hang from your ankles .I tried one of these years ago and I felt like all the pressure was on my ankles and knees so I went with the Dex II.Anyway my back feels like its getting better.I used to hurt so much in the mornings that I could barely walk.That has all gone away.I have had MRI's that showed 7 bulging discs in my back after I took a 30ft. fall from a roof.I was rated at 65% disabled from workmans comp.I have seen Chiropractors since the 80's with not much success.Stretching and decompression is working for me and I hope to be pain free soon.Good luck.
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
What do you mean by compressed? Herniated or degenerated? If the disc is gone then there isn't much you can do. What has personally worked for me is joint supplements. People debate their usefulness, but personally they have saved me from surgery twice. Another thing to look into is spinal decompression. So far I have liked that better than the doctor recommended path which is anti-inflammatories -> pain killers -> surgery (either spinal fusion or disc replacement).
2005 XL1200C
Those who trade liberty for security have neither.
Kent's Avatar
Not sure..
All they told me was it was compressed.
There is still some disk but something has been preventing enough fluid from getting in.
Looks like the Chiropractor is helping.
Still can't ride at the moment. Kinda sucks.. Wanted to run up PCH this weekend too.
Since all of you are on Sportsters any seat recommendations? Right now still with the 13 year old stock seat.
el jinete fantasma's Avatar
el jinete fantasma el jinete fantasma is offline
Sportster/Buell Model: XL1200N-Traded :(
Other Motorcycle Model: Harley Fat Bob
Other Motorcycle Year: 09
el jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really niceel jinete fantasma is just really nice
Sorry to hear about the pain, man.
I definitely empathize, after what I went through last summer (pinched nerve). The chiropractor definitely helped a lot. I had about 20 sessions. Sometimes three a week at the beginning. I've gotten into the habit of stretching every morning.
I don't have any suggestions regarding the bike. Even after I'd recovered, I was "aware" of the injury after long rides on the Sporty. This doesn't happen with by Dyna, which stretches me out a bit more, even with mids.
Edward
Pasadena Motorcycle Club
http://pasadenamc.com
Kent's Avatar
Yeah, funny thing to..
First chiro visit I aparently had a pinched nerve for who knows how many years and she opened that up.
Kinda strange to have feeling in a part of my leg that I haven't had in over 10 years.
Mine is setup much like your old nightster as well so that worries me a bit.
I forgot what your bike looks like, but yeah, I would have had to make changes has I kept the bike. The dealer put it on the sales flood a couple weeks ago, so I was able to sit on it for old time's sake. What a revelation! After not riding it for a month and a half, but felt like I being folded up into a suitcase! A more upright seating position and a tall Mustang seat would be a start.
It was about six months before I had feeling back in my left shin... weird.
