Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 8th March 2009
Baggedcereals Baggedcereals is offline
Baggedcereals is an unknown quantity at this point
Default preload for a 09 1200 custom
Hey guys....was wondering how yours rides with the preload set to max load for riding 2 up. Do you bottem out at all? Do you set yours all the way to 5?
Thanks
Old 9th March 2009
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
I'm not sure what this will tell you. It depends on the weight of the riders, the kind of roads you ride on, the way you ride, …
Folkie
South East England Riders
Old 9th March 2009
just seeing what everyone sets there's at. and how they ride on the settings.
i know the bumppy roads suck...and i will more than lickley bottem out.
how much does setting the preload to max help you guys?
Old 9th March 2009
Urrell's Avatar
Urrell Urrell is offline
Other Motorcycle Model: Electra Glide Ultra Class
Other Motorcycle Year: 2009
Urrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of light
Like Folkie said it matters more what weight you are carrying at the time and the style of riding and the smoothness of the road. I am about 240lb ready to ride and the other half is about the same and I set my 2005 1200c to position 4 for me and 5 for 2 up. It still bottomed out so I changed to 12" Progressive 412 heavy duty. I now ride on position 2 and 4 for 2 up and am very happy with the ride, So much so that I now have replaced the fork springs with the Progressive ones.
Old 9th March 2009
i weigh 165 and the wife weighs about 150. Should i be ok with the stock shocks? or should i look into the progressive set
Old 9th March 2009
Urrell's Avatar
Its only you who can make that decision. Read the manual or search here how to set the rider sag. How does it ride now. Almost any shock will bottom out if the bump is severe enough. You just want to adjust them for a comfortable and safe ride.
