Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Last Post: blindfredy
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
Last Post: sevenyears of famine
Last Post: friday
Last Post: guitarfish
0 oil pouring out on right side
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
Old 11th January 2007
asepahmad's Avatar
asepahmad asepahmad is offline
Sportster/Buell Model: Stroked Sportster
asepahmad is an unknown quantity at this point
Default cam for thunderbolt s2
Hi All,
My scoot has been transplated with a complete buell thunderbolt s2. Question is would a set of mild cam be an improvement? Currently using stock s2 heads. Any brands/type recommended?
Also using stock 883 ignition module, should i upgrade this first?
Not sure which direction to go next...
ride hard or stay home ;-)
Mattbastard's Avatar
Mattbastard Mattbastard is offline
Bike Builder
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: V-Strom 1000
Other Motorcycle Year: 2014
Mattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of lightMattbastard is a glorious beacon of light
I THINK the S2 cams are "D" cams, just like in the sporty's of that era.
wildwill8's Avatar
wildwill8 wildwill8 is offline
Sportster/Buell Model: 06 Redneck Mutant
wildwill8 is on a distinguished roadwildwill8 is on a distinguished roadwildwill8 is on a distinguished road
the Thunderbolt is the samething as a Sporty motor I hope your motor was blown when you changed it out if not you just wasted money.
asepahmad's Avatar
old motor was pretty much blown, would upgrading cams be a good option then?
wildwill8's Avatar
I would got with a Andrews N4 I think this is about ass big as you can go with a stock motor I have a set of cams out of a 95 S-2 Motor if you are just needing cams I have the hole topend head cylinders pushrods and cams.
Old 15th January 2007
asepahmad's Avatar
would i need to change other stuff like valve springs, pushrods or anything else to install Andrews N4?
chrishajer's Avatar
Sportster/Buell Year: 1988
Next direction to go, for performance? GET RID OF the drag pipes. Changing to a proper ignition module will help too. But get rid of the drag pipes first.
--Chris
Old 16th January 2007
asepahmad's Avatar
Yup, saving up for supertrapp 2-1 as well, just that it cost so much due to shipping cost compared to cams & ignition
Old 22nd January 2007
chrishajer's Avatar
I would spend the money on the pipes before replacing the cams. You'd likely get a bigger bump in street performance.
--Chris
