Last Post: Moon Wolf
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: Beelzeboss
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Last Post: maltesefalcon
Old 21st March 2005
dave's Avatar
dave dave is offline
Other Motorcycle Model: FXDWG (Dyna Wide Glide)
dave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura aboutdave has a spectacular aura about
Default Inspect/lube steering bearings
My 10,000 mile checkup is coming up on Lilybeth (2004 1200C). One of the items specifies that the steering bearings should be inspected and regreased.
Anybody done this? How hard is it to do? Do I have to remove the front wheel and forks? Yes, I have a manual...
Dave Funk: Lafayette, California. 2004 1200 Custom
Old 24th March 2005
Chuck's Avatar
Chuck Chuck is offline
Sportster/Buell Year: 03
Other Motorcycle Model: Elecectra Glide Classic
Other Motorcycle Year: 2010
Chuck is an unknown quantity at this point
Damn Dave, 10,000 miles and year old. You must not even own a car.
My bike has a grease fitting. I just keep it greased. I have about 15,000 on my 98.
2010 FLHTC
Old 24th March 2005
txsporty's Avatar
txsporty txsporty is offline
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
txsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished road
My '03 has a grease fitting also.
If yours doesn't then I would take it apart and check it!!
I pulled my tree's apart just recently to change them out with a powder coated set and was Very surprised at how little grease there was in there!!!
The Manual for my bike tell you to grease them through the fitting until grease comes out of the top and bottom dust shields!!
To pull it apart wasn't that difficult just a pain!!!
Hope that helps!!
Old 24th March 2005
dave's Avatar
I just passed my one year anniversary (3/19). I love it! I think I would sleep with "Lilybeth" if my wife would allow it.
What's a car?
I didn't even think to look! I also love bicycling (and do my own wrenching), so I sorta assumed that the whole front end would have to be disassembled just like a bicycle. Whew! I'll take a look for grease fittings tonight.
Thanks!
Old 24th March 2005
Chuck's Avatar
I must have pumped mine 30 times before grease started to come out.
Old 24th March 2005
I greased my '98 thru the fitting - regret it mucho. Warm weather and it oooooozzzzes out at the bottom. Makes a mess. Best to take it apart, clean it up, and put in just enough new grease. You do not need much! Just use good quality stuff.
Old 24th March 2005
dave's Avatar
How much disassembly is required to get to the bearings? Are there upper and lower bearings?
Old 24th March 2005
dave's Avatar
Last night, I took a good look at my manual and at Lilybeth. I see nothing in the manual about a grease fitting, and I don't see one on the bike either (2004 1200 Custom).
So I guess I will have to do some disassembly to get to the bearings. The manual, unfortunately, has nothing to say about this procedure. It just has an exploded diagram and the words "inspect and lubricate the steering bearings". Gee, thanks...
So again I ask: Anybody have any guidance for me on how to do this? Hopefully, I don't have to disconnect the front brake, remove the front tire, and remove the forks to get to the bearings...
Old 25th March 2005
dave's Avatar
I guess nobody out there can help me..?
Just wanted to know if there were any guidance / suggestions for the disassembly required to service the steering bearings.
Oh well...
Old 26th March 2005
I dismantled the whole front end of my 1980. Have not done that on my '98 or on any of my previous bikes. I am surprised that the manual is not much help. Perhaps a Clymer manual would be better. It is not a difficult job. But i would think that a manual would be necessary.
The hard part with the '80 was putting the wireing and parts back together in the correct sequence. I had to dismantle and re-start 2 times. But i was putting it back together a couple months after stripping it down. It would be easier done on a single weekend, say.
Similar Threads
Removing/Installing wheel bearings sean883 Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 13 4th August 2017 18:32
Steering Stem bolt Torque 883Hugger Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 44 14th May 2015 15:00
steering neck changes, 04 & up? Benetampa Rubber Mount Sportster Motorcycle Talk (2004-2006) 5 29th January 2005 20:52
