Last Post: Hank21113
0 too bad
0 Head gaskets.
0 Dynamic timing the 2000i?
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 blonde, brunette, red?
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
0 Nighster seat on Iron
Last Post: ed_in_az
Last Post: lo-rider
Old 15th January 2007
Gary7's Avatar
Gary7 Gary7 is offline
Sportster/Buell Model: XL883 (traded)
Other Motorcycle Model: FXDC Super Glide
Other Motorcycle Year: 2009
Gary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the rough
Default Part numbers for 07 sprockets?
I'm thinking about changing out my 28T front sprocket for either a 29T or the 30T that comes on export XLs. I know the 07 has unique sprockets because of the new narrower belt, so does anyone have the HD part numbers for the 29T and 30T sprockets? Thanks.
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
My parts manual lists the following:
40379-04 - 28T
40409-04 - 29T
40380-04 - 30T
I've been looking at this myself. How are you going to change the speedometer to read correctly? Or are you not going to worry about it?
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Gary7's Avatar
40379-04 - 28T
40409-04 - 29T
40380-04 - 30T
I hadn't planned to worry about the speedo unless it turns out to be WAY off.
Those part numbers bother me. The -04 would indicate they are for 04 to 06 bikes. I'm pretty sure I read that the 07 carbon fiber belts are narrower, so would this not necessitate a different sprocket?
Well, the numbers are right out of my 2007 HD parts Catalog (part number 99451-07).
I can't answer about the belt being narrower. I know the belt is different, but I didn't realize narrower. I just thought it was made of different material (but I could be totally wrong). The parts catalog does list the belts as:
40371-07 136T (883's)
40591-07 137T (1200's)
d_dieffenbach's Avatar
d_dieffenbach d_dieffenbach is offline
Sportster/Buell Model: xl1200c orange and black
Sportster/Buell Model #2: xl1200r traded on 08
Sportster/Buell Year #2: 2004
d_dieffenbach has disabled reputation
Gary i dont believe the belts on the 07,s are any different than the 04 to 06. i am not sure why they would put a narrower belt on the 07,s the tire size is still the same on 04 and newer sportsters.
I rode mine to sturgis!
http://i123.photobucket.com/albums/o312/harleyxlr/100_1397.jpg
Gary7's Avatar
I could have sworn I read somewhere on the HD web site that the new carbon fiber belts for the XL were narrower.
Oh well...
Old 16th January 2007
gary just curious how wide is your belt on your 07. my belt on my 04 is 1 1/8inches wide.gary they may have change the belt to a newer better belt. who knows.
snowman's Avatar
snowman snowman is offline
Originally Posted by d_dieffenbach View Post
gary just curious how wide is your belt on your 07. my belt on my 04 is 1 1/4inches wide.gary they may have change the belt to a newer better belt. who knows.
04-06 belts should be 1 1/8". 2007 softails went to a 20mm (3/4") wide belt. All are 14mm pitch on the teeth spacing.....
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
cadiero's Avatar
cadiero cadiero is offline
Other Motorcycle Model: BMW R1200RT
cadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to beholdcadiero is a splendid one to behold
The '07 Sportster belt is narrower. It is a better belt, all HD's went to a narrower belt in '07.
But, why does the sprocket need to be narrower? Can't a narrower belt run on a wider sprocket? Well it can, the sprockets didn't change, those are the right part #'s.
BTW, when Big Twin's went from a 1 1/2" belt to a 1 1/8" belt the front sprocket remained unchanged still to this day.
Old 18th January 2007
prplhays's Avatar
prplhays prplhays is offline
Sportster/Buell Model: XL883L Superlow
Sportster/Buell Year: 2012
prplhays is an unknown quantity at this point
One other thing to consider is if you jump from a 28T to a 30T you may need a new belt because the old belt may not be long enough. I went from a 28T to a 29T and I had ample belt length, but I've seen on this forum that jumping up two sizes could necessitate a belt change.
2005 Sportster XL883 - sold, 2006 VRSCR VROD - sold, 2012 XL883L Superlow
