0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Last Post: nakina
5 Transmission HELP!
Last Post: MatHormell
0 strange small wires attached to coil
0 90 in. Build
0 24633-77 Breather assembly
Old 16th March 2009
Charles Kelley's Avatar
Charles Kelley Charles Kelley is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1200 low
Charles Kelley has disabled reputation
Default change the oil in my 73 Xlch
Just kinda curious, What's the best way to change the oil in my 73 Xlch? I know their are several drain plugs, and a primary plug. Is it necessary to purge the lines? I know it's not a good idea to remove one or more of these plugs. As always your responses are greatly appreciated.
Old 16th March 2009
Not necessary to purge, or to ensure that every last drop of used oil is out of there. There are two oils - engine oil and primary oil.
The engine oil is usually just drained from the oil tank. This will typically leave 1/2 quart or so of oil behind and we just do not think about it. One drain plug for that.
The primary oil is usually drained from a drain plug on the bottom of the case, on the left side, just behind the footpeg position. There may be one or two other pipe plugs elsewhere on the bottom, but the usual recomendation it to leave these alone.
If any plugs are unusable then use a "drill pump" or similar to remove any oil.
Old 16th March 2009
Thank's
Charles
Old 16th March 2009
Barkster's Avatar
Barkster Barkster is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: Yamaha RT1
Sportster/Buell Year #2: 1971
Other Motorcycle Model: CR500R
Other Motorcycle Year: 1987
Barkster is an unknown quantity at this point
Do not remove the drain plug which drains the oil out of the crankshaft during oil changes. The treads tend to strip easily.
Nitrous is like a hot chick with STD's, you know you want to hit it but your afraid of the consequences.
Old 27th November 2009
Does any one know if the clutch spacers used on the 74 pressure plate can be uued on the 73 I know the manual calls for a specific distance from the release disc to the drive plate. The 74 setup calls for them the 73 does not. Is the 74 set up any better? as I had used a set of dial calipers last time to set the distance per the manual specs, with the spacers you just snug down the nuts and your done.I'[m having slippage issues]
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Yes they can , and you can make then using steel brake line tubing.
What's the required I.D. of the tubing?
Ivan RoachCoach's Avatar
Banned
Default The studs are 1/4" diameter, so 1/4" I.D. tubing is fine...
...If they snag up on you, just give them a light pass with a round file.
Old 28th November 2009
Thanx Ivan.
