Last Post: roadsterboy
Last Post: Airbozo
Last Post: _Outlaw
Last Post: mor
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
Old 20th March 2009
FoxsterUK's Avatar
Default Here's how to get steel splinters out of your fingers
I seem to get quite a few slivers of metal stuck in my fingers from using steel wool or picking up bits of swarf when I have been drilling. Unlike wood splinters which dissolve or are generally large enough to see and pull out, metal splinters seem to burrow their way in and leave that little stabbing pain sensation when touched that tells you something is in there. Here's how I just figured out to remove them...
First you need an old hard drive from a PC; if its not the sort of thing you have lying around then try the local PC shop, they throw them away on an almost daily basis. Gently remove the metal cover of the hard drive with a sledge hammer and chisel (or screwdriver if you want to pansy about). There is an arm that moves over the disk surface and what you need sits under the fixed end of this arm. Undo the screws holding the arm mechanism in place and you should find two shiny flat "super magnets". These are very strong magnets, much stronger that your normal magnets.
To remove your metal splinter you just need to pass this magnet over the painful area and with a bit of luck the splinter will be sucked right out. I've just tried it with two splinters and both came straight out.
Have fun.
Doc Fox
Old 20th March 2009
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Cool
Super tip Doc;
I have one of these magnets stuck to the lower outside (and out of sight) of my oil tank to capture any metal shavings that may be circulating around. I also use one when I drain my primary oil. Hold and run it along the underside of the casing a few times then up to the plug hole (plug removed) to drag anything out of there...
Old 20th March 2009
brimic's Avatar
brimic brimic is offline
Sportster/Buell Year: 1990
Other Motorcycle Model: Fxdwg
Other Motorcycle Year: 98
brimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the roughbrimic is a jewel in the rough
Ooh, I'll have to try that out someday. We have a superconducting supermagnet at work -nuclear magnet resonance machine http://en.wikipedia.org/wiki/Nuclear_magnetic_resonance The only bad part is that its powerful enough to suck a sliver through your finger the wrong way
TANSTAAFL
Old 20th March 2009
funnythebunny's Avatar
Senior Bike Builder
Sportster/Buell Model: XL883L Superlow
Sportster/Buell Model #2: FLHTKL Limited Low
Sportster/Buell Year #2: 2015
Other Motorcycle Model: FLSTN Softail Deluxe
Other Motorcycle Year: 2011
Ouch!! is it portable? I might need one at work, since I'm surrounded by steel.
Old 20th March 2009
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
im thinking i may not want to be anywhere near a magnet like that as my shoulder and knee are screwed together. however it would be quite a sight
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
Old 20th March 2009
brimic's Avatar
Yep, ferrous or electronic (pace makers) are completely out of the question. The thing will kill your credit cards if you forget to leave your wallet outside of the room.
One of my coworkers has had surgery on his shoulder a year or so ago, and has screws, but he hasn't had any problems- must be titanium or nonmagnetic stainless screws.
Ours is pretty small, its only a 300Mhz unit, but its still a stainless tank that stands about 6' high and is about 3' in diameter.
Old 20th March 2009
khaskins's Avatar
khaskins khaskins is online now
Other Motorcycle Year: 1970
No MRI for you. I seen the magnets on the MRI rip a mop out of a janitor's hand on a safety training video. Makes anything steel a deadly missile.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 20th March 2009
Kirk the Jerk Kirk the Jerk is offline
Senior Bike Builder
Sportster/Buell Model: None
Sportster/Buell Year: None
Kirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to all
There was a news article a while back I read about how someone tried rushing a gas cylinder into the MRI room, because they were out of oxygen, or something like that, and when it was ripped out of their hand killing the patient...
http://www.mri-planning.com/articles...ars_after.html
4th paragraph tells the tale.
Old 20th March 2009
xlint89's Avatar
xlint89 xlint89 is offline
Sportster/Buell Year: 89
xlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura about
Not a bad idea, I'll tyry that sometime.
I usually use a razor blade (standing on edge) to scrape over the area. Works pretty well.
Stock............. Isn't that a soup or something?
Old 20th March 2009
gamhill gamhill is offline
gamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura about
[quote=FoxsterUK;1815232]... Gently remove the metal cover of the hard drive with a sledge hammer and chisel (or screwdriver if you want to pansy about)....
Good tip - You need to add the standard lawyer speak about always wear googles....
