Last Post: Vohnsen
Last Post: conv90
Last Post: groovemeisterus
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Last Post: nakina
Old 20th March 2009
SuperTed's Avatar
SuperTed SuperTed is offline
Other Motorcycle Model: Fairlane 500
Other Motorcycle Year: 1964
SuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to all
Default Idle Cable?
I want to take the idle cable off my '01 1200C. Can it just come straight off without having to do anything else to the carb?
Old 20th March 2009
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
I beleive you can just take it off. The only thing is that your throttle will not snap back to idle when you let go of it - you'll have to roll it back to idle by hand.
Others will chime in that know for sure.
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 20th March 2009
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
The answer is yes. You don't need it. I threw mine over board years ago.
Old 20th March 2009
SuperTed's Avatar
OK, so the only purpose of the idle cable is to snap the throttle back to idle? So without the idle cable, do you have to "roll off" the throttle between shifts? Doesn't sound like much extra effort.
Old 20th March 2009
biknut's Avatar
No. You're misunderstanding the purpose of the idle cable. A spring on the throttle plate shaft snaps the throttle back to idle.
The idle cable is a safety devise that allows you to force the throttle to close in case the throttle gets stuck open. It was mandated by big brother. If your throttle never gets stuck it never does anything.
Old 20th March 2009
Alistair Alistair is offline
Alistair is an unknown quantity at this point
Yup, safety device to ensure you can shut the throttle should the small spring in the TB/carb snap. Do you need the idle cable for the bike to run? Nope. Would I remove it? Nope.
Old 20th March 2009
SuperTed's Avatar
Damn that big brother - putting warning labels all over everything and idle cables on motorcycles! So the spring at the end of the idle cable sort of does the job of returning the engine to idle should the spring on the throttle plate shaft snap? Like a back-up spring so to speak?
It's coming off.
Old 21st March 2009
biknut's Avatar
It's coming off.
No not really. When the idle cable is adjusted properly it has a lot of slop in it. It really doesn't have anything to do with the idle. It's just a cable that allows you to force the throttle to close if for some reason it gets stuck open. That's it's only function.
In the event that ever happened you could always just hit the kill button.
Old 21st March 2009
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
Sportster/Buell Year: 0
jimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of light
I've had bikes with one cable and I've had bikes with 2.
It SHOULD still snap back with only one cable.
The second cable is more of a safety feature in case the throttle gets stuck at the carb, as stated by biknut.
Old 21st March 2009
biknut's Avatar
More correctly they should have called it an emergency cable, but that would probably scare people.
My car doesn't have a idle cable. Someone call Obama.
