0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 21st March 2009
jkilala jkilala is offline
Sportster/Buell Model: sportster xlch
jkilala is an unknown quantity at this point
Default shock absorbers
hey there fellow enthusiast i need to know if im an idiot for thinking i can keep 12.5 inch shocks on my bike with a very stiff spring 13.5 is the lowest everyone says to go i know, but i have really sweet shocks dont want to get others my ride is a 1975 ironhead sporty xlch
Old 21st March 2009
runingmouse's Avatar
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura aboutruningmouse has a spectacular aura about
I'm not sure what your asking hear. Are the stock shocks 12.5? There are three settings on stock shocks for weight adjustments. Unless yov have changed something like the front end, I don't know why you would want 1 more inch higher. Unless your stock schocks are 13.5. If thats the case you have answered your question.
In other words 12.5 if not stock. Only after (lowering) kit for front end. If that what your trying to do. If you like riding safe!
Old 23rd March 2009
irnhdmike irnhdmike is offline
Sportster/Buell Year: 1969
irnhdmike is an unknown quantity at this point
Your rear tire will hit your fender with 12.5 " shocks. Also depending on exhaust it will hit pavement before shocks bottom out.
Old 23rd March 2009
Jackster's Avatar
Jackster Jackster is offline
Sportster/Buell Model: XL 1200R
Sportster/Buell Model #2: XL 883
Sportster/Buell Year #2: 1986
Jackster has disabled reputation
Just readjust the fender and problem solved. I ran 10.5 inch shocks and didn't bottom out.
Old 23rd March 2009
Up to 78 needs the longer shocks.
Old 23rd March 2009
kscott's Avatar
kscott kscott is offline
Sportster/Buell Model #2: 1200C
kscott is an unknown quantity at this point
Stock on the 75 is 14-1/2. I tried 12's on mine and the fender was right on the tire...more importantly the chain was hitting the sprocket cover. I have some 13-1/2 now with preload at the top and I don't think you could get any lower without radical changes.
1975 XLCH
Old 23rd March 2009
ironheadjim's Avatar
ironheadjim ironheadjim is offline
ironheadjim has disabled reputation
my 77 has 12.5s with a 16" rear meat and the clearance is only about 1/4" with engine off the frame. Going to have to do something diff.
Old 23rd March 2009
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
I got 12.5 fx shocks on mine, it hits now and then two up but by myself its all good.
I also have a fatbob rear fender that I carefully centered over the wheel to give me as much room as possible
"lord of the Night Lite"
thank god for darwin ;)
Old 23rd March 2009
Gone Gone is offline
someone needs to explain to me how to "readjust" the fender. 10.5" shocks on a 75 IRONHEAD will put the tire right into the fender, which is very nonadjustable. they might work on your new EVO sporty, but no way will they work on an mid 70's IH
Old 23rd March 2009
Ivan RoachCoach's Avatar
Banned
Default I'm running 12" shocks off a BT with a 16" rear tire on my'74...
...with no clearance issues whatsoever.
This is with a stock '74 rear fender and no frame mods whatsoever.
