0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
0 1974 Ironhead
Last Post: frogg_nutts
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
Old 23rd March 2005
hdsporty's Avatar
hdsporty hdsporty is offline
hdsporty has disabled reputation
Default Freshly painted tank problems!!!
hi everyone. i just recently got my bike painted and i just noticed that there is some surface rust on the inside of the tank. it is a 2002 1200C and i know there wasnt any rust in there when i took it off so do you think its from the painter wet sanding and the water just sittin there for about a week?. i dont wanna get a new tank b.c i just got it painted so what should i do without wrecking the paintjob?. just rinse it out with something and call it good? any info would be awesome.
Old 23rd March 2005
mikeLI_77's Avatar
the dealers will treat it with some sort of acid bath. I had it done to my last bike and it did not affect the paint at all.
you can look at this stuff:
http://www.prp-porshop.com/merchant....gory_Code=Kits
this one says it will not hurt your paint:
http://www.rusteco.com/MotorcycleCruiser.htm
and this one:
http://www.hoeseler-por15.com/16_e.htm
2002 XL1200C (originally)
Supertrapp supermeg exhaust 20 disks and open end cap, S&S roller rockers, Alto Carbonite clutch with Energy One 15% heavier spring plate, Daytona twin tech single fire ignition 1005s
Ricor intimnators, 13" Ricor IAS shocks, Brembo dual disk setup from a 2012 street glide with matching brembo street glide master cylinder,
States I Have rode through
Old 23rd March 2005
I had thought that all HD tanks were rustproofed at the factory. Don't remember where i heard that. May be incorrect.
I have taken all of my rusty tanks to a local auto radiator shop that specializes in fixing that problem. Cost less than $100.00. I have heard stories of guys who did the job themselves only to have the coating come off later. Tank is then junk. IMO it is a job for an experienced hand.
If you do it yourself you must: be certain that all rust is out before coating; follow all instaructions exactly & carefully.
Also i believe the following to be important: NEVER allow water into a fuel tank. You cannot ever ever ever get it all out. It WILL rust. Absolutely.
Old 24th March 2005
rottenralph's Avatar
why not get some kreem coat and seal the tank again. I certainly would not get rid of it because it has a spot of rust. Yours is not the first and won't be the last.
Old 24th March 2005
hdsporty's Avatar
well, i put some cleaner through my tank and it took most of the rust stuff out of it and i realized that there is some sort of coating that is in the tank and the rust isnt that bad so i got all the cleaner out and called my local HD dealer and he said if its not terribly bad then dont mess with that sealer KREEM stuff and just get out what will come out and fill it up with gas and i should be fine. so i did and if i ever have any future problems, ill just buy a new tank and have it painted to match my custom stuff. thanks guys!
Old 24th March 2005
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the roughstevo is a jewel in the rough
POR 15 tank sealer.......the only stuff I use and recomend
Old 24th March 2005
Joe S. Joe S. is offline
Other Motorcycle Model: Harley Davidson FXD
Joe S. has disabled reputation
If necessary I would think about sending it to Rusteco. Their process will not hurt the tank, I had my FXD done after it was painted and absolutely no harm was done. It is not a coating and it will not peel as Kreem has been known to do.
Interesting side light. HD has indeed put some type of lining in most of their tanks. the reason I had the Rusteco process done is that mine was found to be bubbled and beginning to peel one year after i had the bike painted. Curiously this was a factory new tank bought when the bike was painted (accident repair). HD would not warrant it, not to surprisingly, but my dealer did pay for the Rusteco treatment outof their pockets which was a very pleasant surprise.
Since that time I have seen several tanks that have been found to have the liner seperating, I don't think it is common to find it because its hard to see into the tanks and there actually aren't many reasons to go looking, could create a problem in the higher pressure fuel injected systems though if that stuff clogs things up. HD has a service bulletin on it and I note that on some models they have now changed to a plating of some sort rather than a lining.
'09 XR1200 '06 Tiger955i
'03 SV1000 '02 GL1800
'01 HD FXD '07 DR650
Old 24th March 2005
Chip's Avatar
Chip Chip is offline
Other Motorcycle Year: 1998
Chip is on a distinguished roadChip is on a distinguished roadChip is on a distinguished road
When I purchased my 2" strectched tank I had to prep the outside and the inside as the factory puts a light coat of oil on them. Buy a Kreem prep kit and instructions will tell you how to remove the rust. Have done 2 tanks and not had any problems
Similar Threads
help with installing new tank kntalan Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 11 15th May 2005 08:12
FRESHLY PAINTED 2002!!!! hdsporty Sportster Motorcycle Custom Finishing 24 8th May 2005 14:12
Found the bottom of my gas tank! gilx Sportster Motorcycle General Discussion and Problems 12 5th May 2005 19:45
Removing reflectors from fender Geek Sportster Motorcycle Custom Finishing 8 9th March 2005 01:27
Tank Expansion or Horizontal Stretch Speedy818 Sportster Motorcycle Custom Finishing 4 1st January 2005 22:39
