25th March 2009
Posts: 185 Sportster/Buell Model: xlh Sportster/Buell Year: 1988 Sportster/Buell Model #2: xlh Sportster/Buell Year #2: 1984
i need a little advice with my engine build
i have a 1988 1200 and its time to do a top end change its got about 50,000 miles on it. the rocker box gaskets are leaking and im starting to get a little silver tint in my oil. i want to do a 1250 conversion and i was wondering if i can use my stock jugs and bore them to fit the 1250 pistons. a good friend of mine has a set of 883 heads off of his 98 sportster and i might buy those and have them worked. i need some advice on what i should do with my motor. any advice would be greatly appreciated
;)1988 1200
25th March 2009
Posts: 862 Sportster/Buell Model: XL Sportster/Buell Year: 89
You cannot bore stock cyls to a 1250. They can be bored for a 1212 max.
883 heads worked, will cost more and gain less than buying 1200 heads off Ebay. How about porting your heads?
My suggestion to you is to buy a set of Thunderstorm heads and pistons. Use your stock cyls and get around 80 HP and 80 TQ with good cams and exhaust.
Or you can buy the XB heads and use them with your cyls. Will need a different intake flange though.
Many options available to you. How much $$$ and how much HP do you want?
Stock............. Isn't that a soup or something?
25th March 2009
Posts: 15,243 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997
actually the most you can go on a stock 1200 jug is .040 over which is a 1228
but Needless to say the 1250 kit uses a special set of jugs made by axtell for NRHS that allow it to be bored to to 1250 cc. Cost starts at $700.00 and includes everything needed to get er done.
While the 883 heads can be worked, seeing that you already have 1200 heads, you're best money would be to have them worked to match the pistons, you can get a higher compression vs going with an 883 head.
The Thunderstorm setup is great for people looking to go a little over stock, or if you can afford it, going with Buell XB heads or 2004+ Heads are a better choice.
States I've Ridden in
71.3 hp 70.8 tq
25th March 2009
Posts: 6,386 Sportster/Buell Model: XLRR Sportster/Buell Year: 91 Sportster/Buell Model #2: XLH1100 Sportster/Buell Year #2: 80
I think I'd go with the 1250 kit and get your 1200 heads worked...... maybe a set of N5 cams and put some good pipes on it..... and you'll be loving it for the next 50,000 miles
Ww
master wizard
[B][COLOR="Red"]Super Moderator[/COLOR][/B]
[FONT="Book Antiqua"][B][U]RIP Mr Jimi[/U][/B][/FONT]
"All The Way"
25th March 2009
im working on a budget of about 1000 dollars and want the most i can get. i read in another thread that stock 1200 heads arent really great for making power. i was thinking about a 1250 with either v4 or v6 cams. also what is the difference between v cams and n cams from andrews? i know they are for different years but why wont they interchange
25th March 2009
Posts: 1,199 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XR-1000 Sportster/Buell Year #2: 1984
You can buy a SE 1200 conversion kit for about 1K and get new cylinders, pistons, rings AND a set of 1200R heads.
Now, you will have a updated 1200 with the 1200R heads. This is the best bang for your buck as the early 1200 heads are garbage performance wise. (See NRHS section on heads) Also, it will provide a great foundation for future mods.
CAUTION: Check your lower end. If, you are seeing silver in the oil. Sounds like a bearing is going bad. You may have to rebuild that as well.
Good luck my friend.
Reason: more data
25th March 2009
Jesse is right, you need to make sure the bottom is good before you rebuild the top end. 50k mi and silver tinted oil does sound like a bottom end inspection is important.
You may want to put your $$ towards that before building her up.
Since you already have a 1200, the 1250 kit is a waste IMO. If you had a 883 and were going big bore, it would be worth it. But $700 to gain 50 cc and 2-3 HP.... not worth the $$
Have your heads ported stage 1 OR (after re-reading Iwantmybeerbackplease 883 build) buy your buddy's 883 heads and have the competition valve job done.
Get a set of the V4 cams (Andrews V are for 4 spd with N being for 5 spd. They are different)
Get rid of the drag pipes. Take the left over $$ and buy a good exhaust. I recommend Bassani Pro streets if you like the drag pipe look and sound. They make good power without going to a 2-1. Also can be had for a good price on Ebay. Seen them NEW for $300 before.
This should run close to $1000 and give you significant gains over what you have now. And a really strong early torque curve.
25th March 2009
XLF LIFEMEMBER Im retired
Posts: 14,299 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
+1 and plan on bottom end work. You would have a fresh engine. $1000 budget for a 21 year old scoot may not be enough. Good luck.
25th March 2009
They won't interchange because of the differences in the pinion gear and the style of the cam's themselves. Different teeth configurations and such.
If you're considering the budget. Get larger pistons, a re-bore and have some head work done, along with a set of cams, should Perk up that engine and keep you on track.
I also agree that you may want to take a CLOSE look at the bottom end..
25th March 2009
Posts: 1,798 Sportster/Buell Model: 883/1212 XL Custom Sportster/Buell Year: 2004 Sportster/Buell Model #2: XLCH STROKER Sportster/Buell Year #2: 1959
Now, you will have a real 1200. With mote power to boot.
+1 what jesse said.
You can buy the complete kit for $1000.00 like he said from a couple of online dealers. It's all late model stuff which will produce more than enough power than the conversion you orginally talked about.
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
