0 Brake Squeek
Last Post: Tucsonmax1
Last Post: cazz1000
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
1250, big bore, conversion, evo
Old 25th March 2009
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
Again...
check your bottom end before you dump money on top! It's critical...
Old 25th March 2009
NC_REDNECK_1981's Avatar
NC_REDNECK_1981 NC_REDNECK_1981 is offline
Sportster/Buell Year: 1988
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1984
NC_REDNECK_1981 is an unknown quantity at this point
thanks for all the advice. i will be sure to check the bottom end. i am leaning towards boring my jugs to .040 with v4 cams and try to find a set of thunderstorm heads. anyone know how much hp and torque i would be looking at doing this build?
;)1988 1200
Old 26th March 2009
xlint89's Avatar
xlint89 xlint89 is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 89
xlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura aboutxlint89 has a spectacular aura about
Thunderstorm heads REQUIRE thunderstorm pistons for true performance gain.
I had v4 with the TS set up, a Super E carb, Dyna ign and Bassani Pro Streets. Got me 83 HP and 79 TQ.
TS likes Higher RPM for it's power.
You can have your heads ported for better low end TQ for about the same cost as the TS heads off Ebay.
Alot of power comes from your exhaust. Your drag pipes are hurting you, unless you run WOT everywhere.
Stock............. Isn't that a soup or something?
Old 26th March 2009
Oklahoma's Avatar
Oklahoma Oklahoma is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 1991
Sportster/Buell Model #2: XLA
Sportster/Buell Year #2: 1957
Other Motorcycle Model: FL
Other Motorcycle Year: 1961
Oklahoma is an unknown quantity at this point
I have been thinking about this type of upgrade for a 91 1200 I have. Thanks for all the good advice. NC Redneck post your updates when you do the job I'd be interested in what you do.
Old 30th March 2009
ok i checked the bottom end and nothing wrong down there . i just bought a set of thunderstorm heads and wiseco pistons .040 over to match the thunderstorm heads, now for cam selection i have been looking and comparing andrews v4 and v8 cams.has anyone ever compared the cams and which one would be a better choice. i dont run wot all the time but i do run the hell out of it . i see the v8 cams have more exhaust duration than the v4 cams. how would these do on the street?
Old 30th March 2009
ReddTigger's Avatar
I've asked this question numerous times, and it appears the best choice is the V4 (mine is N4 because of the year) The little bit of exhaust duration isn't that big of a factor without a lot more engine mods.
The V4 or Screaming Eagle .497 (almost identical) are a great choice for all around use and will pull up to 6500 rpm's
States I've Ridden in
71.3 hp 70.8 tq
Old 30th March 2009
the reason i asked is because i found a set of v8 cams for $269. would it hurt or help to get these? or would they perform the same as the v4 cams?
Old 30th March 2009
nevermind. i didnt read the last post right.i will keep looking for a set of v4 cams maybe i can find a deal on a set
Old 30th March 2009
xlint89's Avatar
Do you plan on doing any more to the bike? Something like stage II head porting.
If you are, then consider a larger cam than a V4
If you plan on leaving it alone, get the V4. (I had this set up and it works well)
Now if you check the classifieds in here, someone was selling SE 536's for a 4 spd, (with springs I think) for $200 NEW.
That's another good combo. Actually am pretty sure that's what Buell installed from the factory. They should still bolt in with no mods needed. Just double check to be sure...
Old 30th March 2009
i plan on having the heads ported and polished,as well as polishing the intake. i want her to breathe.
