0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 Curious as to what I actually have
Last Post: JakRabbit
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 THE Trainspotting Thread
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 28th March 2009
criio1's Avatar
criio1 criio1 is offline
Sportster/Buell Model: Custom build,
Sportster/Buell Year: 09
criio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the roughcriio1 is a jewel in the rough
Feel free to add your tips (things to look at during initial inspection) on buying a used sporty besides just checking tires and chain, feel free to add era specific info too.
I wish I had x-ray vision to check out the bearings and cams on used bikes!
I am thinking of getting a 1986 883 bike to chop up for a charity build/raffle (http://www.picturebridal.com/casterfund.html)
I am not sure but I will probably have to crack the case. One thing that holds me back is that the mileage is unknown!
One thing I bring is a magnet to dip in the oil tank! and always check the gas tank.
Old 28th March 2009
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Check out the swingarm play, and headstock play.
Also look to see if the wiring harness has been hacked about [wires added into it, how well was it done?]
Fork slider play, worn bushs or sliders?
Old 28th March 2009
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
I would do a compression check and maybe a compression leakdown test. You might also take off the drive pulley cover and check for side play in the output shaft. If it is badly worn it should leak here also which would indicate a LOT of miles or some really hard miles.
Old 28th March 2009
Hey, it only takes a minute to look at the brake fluid, and check tire pressure if only to see if the seller bothered, checking on the sidewalls could indicate neglect as well as age.
Old 28th March 2009
criio1's Avatar
not a bad idea. but if i was selling a bike and someone showed up with a compression meter i would be puzzled!
I have a tendency to modify everything I own..
Ride Hard
Old 28th March 2009
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
I don't know about pulling covers to check play or doing a leak down test, but I've checked the compression on bikes and cars before, usually the seller knows something about motors and understands. If they don't want me to pull the plugs, theres usually a reason.
Old 28th March 2009
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
when I'm looking at a used car or bike I look for new stuff..... I would rather see older but good plugs/ wires/ filters/ oil ect., it shows how the bike has been taken care of and ridden..... If someone just freshened it up that might indicate someone has been chasing a problem and they just gave up......especially if you see new engine gaskets and stuff like that.....
start it up and get it warm.... take it for a ride, if it looks and sounds and rides okay.... it probably is
Ww
master wizard
RIP Mr Jimi
"All The Way"
Old 28th March 2009
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Depends on the bike, really....age, condition, miles...
I WOULD keep a compression gauge handy, just in case....but I'd only break that out if I was suspicious, or if the bike didn't run, but would turn over......
Most good points have already been covered....
I REALLY like the "magnet in the oil tank" idea.....never thought of that!
IMHO, nothing will tell you more about a bike than a test ride...even listening to it idle will tell you a lot about the engine itself.......
Even if the owner is nervous about letting you ride it (understandable, unless you insured it yourself in advance, like I did on my last bike purchase ), I'd roll it and shift thru all the gears, just to make sure all seemed ok in THAT area...
I never tried it myself, but I think carfax will do motorcycles, as well....not a terrible idea...
I bought both of my last 2 Sportsters used, and was able to ride them first...that, fluid conditions and service records (even hand-written) told me all I needed to know....
BTW, I thought this was a GREAT thread, so I made it a sticky....
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 29th March 2009
Seedless Seedless is offline
Seedless is on a distinguished roadSeedless is on a distinguished roadSeedless is on a distinguished road
Default Used bike evaluation guide
Not sure if this has been linked before...but pretty good as far as a used bike evaluation guide. I read it a couple times before I really began shopping for my sporty. Worth the read.
http://www.clarity.net/adam/buying-bike.html
Seeds
Old 29th March 2009
daggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to alldaggar rider is a name known to all
from personal experience, from now on i will rub my finger along the inside of the pipes. oil/gunk type build up. deffinet way of tellin if the bike is burinin oil. for me it was valve seals.
