Last Post: Screw Loose Dan
0 Primary Oil INSANITY!
0 Lowboy frame conversion
0 What jets do you use?
Last Post: David L.
0 FNG from OKC
Last Post: David L.
0 Show your tank decals
Last Post: Tonail
0 Solar battery charging
Last Post: Ranchero50
Last Post: Naplesron
Last Post: Grumpy-Biker
Old 30th March 2009
rustysink rustysink is offline
Sportster/Buell Model: Sportster 1200 XL Custom
rustysink is an unknown quantity at this point
Default 06 39mm fork lengths?
I have an 06 xl custom with 39mm front forks. One of them I am having to replace b/c it is bent. I just baught (2) 39mm forks from the swap meet but they are one inch shorter. I have put on togather using the parts from the bent one and it seem like it will work. What is the differance in the forks? And do I need to do anything else?
Edit Report
Old 30th March 2009
Jackster's Avatar
Jackster Jackster is offline
Sportster/Buell Model: XL 1200R
Sportster/Buell Model #2: XL 883
Sportster/Buell Year #2: 1986
Jackster has disabled reputation
Do the axle and rotor fit? If so, just throw 'em on. I wish I could find some that were an inch shorter for cheap.
Old 30th March 2009
They should fit I only replace the tube I am using the same bottoms on the forks.
Old 30th March 2009
Jackster's Avatar
Oh shit, then you're good man. Just pop 'em in and ride!
Old 30th March 2009
Default Thanks
Thanks for the help!
Old 30th March 2009
Screw Loose Dan's Avatar
Screw Loose Dan Screw Loose Dan is online now
I think I like Sportsters
Sportster/Buell Year #2: 2016
I don't have all the part numbers for the 2006 forks, but I have them for the 2005, 2007->09 listed on this page. You can see the differences. From what I can tell, the slider (lower part) are all the same. The fork tubes, springs and damper tubes are generally where the difference in length comes from (or some combination of those parts).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
