0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
basket, build, engine, engine help
Old 13th April 2010
jagdprcp's Avatar
jagdprcp jagdprcp is offline
Sportster/Buell Year: 1976
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1979
jagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enoughjagdprcp will become famous soon enough
Take the push rods out and see if the motor will spin. If it does, turn it over until both lifters for one cylinder are at their lowest setting. Loosen the lock nuts and adjust the lifters to the lowest setting. Install the pushrods and then adjust them until the pushrods will just spin without binding. Tighten the locknuts and verify that the pushrods will still spin. Rotate the motor and repeat for the other cylinder.
Skeeeter
'76 XLH - 4 5/8" Stroker, Andrews V-9 cams, S&S Super 'E' and Barnett Billet Scorpion Clutch plus some cosmetic stuff
'79 XLH - Mostly stock except for cosmetics (for now!)
Old 13th April 2010
xlch1977's Avatar
xlch1977 xlch1977 is offline
xlch1977 is an unknown quantity at this point
i was hoping i did it right the first time with the cams i have a hd manual that showed me the marks on the cam gears.does the engine have to be on tdc ? because i i removed the timing plug withe the line in the middle and #1 cyl up .
Old 13th April 2010
FourCams's Avatar
FourCams FourCams is offline
Sportster/Buell Year: 1969
Sportster/Buell Year #2: 1972
Other Motorcycle Model: FXSTC
Other Motorcycle Year: 1996
FourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really niceFourCams is just really nice
Yes, the crank needs to be in the right place when you time the cams, but use the mark on the pinion gear, not the timing mark.
♠ 1969 XLCH ♠ 1972 XLCH ♠ 1996 FXSTC ♠
Old 13th April 2010
xlch1977's Avatar
yea the eng will turn with the rods out
Old 13th April 2010
xlch1977's Avatar
that is the gear thats attached to the oil pump right?
Old 13th April 2010
FourCams's Avatar
Yeah. And it has to be installed on the pinion shaft in the right position. Did you remove the pinion gear from the pinion?
If the engine was on tdc and the pinion gear was in the right place, everything should work when the marks are lined up.
Old 13th April 2010
xlch1977's Avatar
no i didnt remove that gear . how do i know if the gear is at the right position?besides using the hd manual.
Old 13th April 2010
FourCams's Avatar
There should be a mark on the pinion shaft and on the pinion gear. They should line up. When they're lined up the mark on the pinion gear needs to be at about 11:00 o'clock pointed towards the center of the rear intake cam bearing.
If you didn't remove the pinion gear from the shaft and it's pointed that direction and all the cam timing marks line up, then you should be in good shape.
Old 13th April 2010
xlch1977's Avatar
ok cool im goin out to the garage to give it another shot . i will get back to soon....
Old 14th April 2010
xlch1977's Avatar
well i took off the gears and retimed the gears and followed the video.everything is moving free.now i have to wait for my cam cover from the machine shop.and the new advance unit and we will see if she starts. thank you very much guys for the help.
