5 How do you Wash your Bike?
Last Post: A Seabee
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: kristyza
0 Question for RB racing exhaust guys/gals
0 Robbie's uncomfortable seat theory
Last Post: robbie202
Last Post: A Seabee
0 Innovative motorsports 3918
Last Post: motorend
10 howdy from australia
0 1991 frame/engine original ground locations
0 Battery reversed, bike dead
0 Fender Fit and Shinko 270 On Rear 4.50x18?
Last Post: A Seabee
0 Rocksett
Last Post: Gone_Shootin
0 EZY Pull for '77 XLCR
0 Jumping and rocking at around 3K rpm
0 GPS Speedo?
0 Bike lost power,back fired and stalled
Last Post: zack74
0 A Mad Lad on a Blast
Last Post: Hornsmith
0 true length of after market brake cable
Last Post: don_don465
0 Cams exhaust note
0 Resistor vs Copper plug wires?
0 Show your bike next to a train
0 1985 XLX Ironhead with Hi-4N Ignition - Spark cuts out at 3500 rpm
0 Oil in air cleaner
Last Post: denguy
0 I guess I'm back
Last Post: Veeflys
0 Ride Report 2019 Black Hills, Grand Teton Mtns., Rocky Mountain Ntl. Park
Old 3rd April 2009
Kirk the Jerk Kirk the Jerk is offline
Senior Bike Builder
Sportster/Buell Model: None
Sportster/Buell Year: None
Kirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to allKirk the Jerk is a name known to all
Default Stripped inspection cover threads... ARE YOU KIDDING ME?!?!
So, went to do my 1,000 mi. service today, and was buttoning everything back up, when I went to torque down my inspection cover screws to 10 ft-lbs as specified by the manual. Well, 84-120 in.-lbs, but that is the same as 7-10 ft-lbs. So the left one done, click, good. Right one...no click. Keeps turning about a quarter turn past where I should be hearing a click.
It's not the torque wrench, she's fine.
I'm thinking to myself, no, really!?!? Open her back up and I find that the actual threaded nub that sticks out is cracked and was still on the screw.
I talked to the local H-D dealer, and they said to bring it in so they can "take a look" at it. We'll see if I'll be the one to drop over 200 bucks for a new primary cover and gasket. *sigh*
I guess from now on I'll take the minimum torque spec, instead of the max.
Anyone else run into this?
Old 3rd April 2009
Kwest187's Avatar
Kwest187 Kwest187 is offline
Sportster/Buell Model: 883/1200 standard XL
Sportster/Buell Year: MUTT
Kwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really nice
ehh...one'll hold it-there is no pressure on that cover-just JB weld the bolt in the hole to fill it...
I'm kidding-
......or am I-I'm sure you can find a way to keep from spending 200 dollars on this-
The horizon will never come into focus-but that doesn't keep me from trying.
Old 3rd April 2009
ivory hunter's Avatar
ivory hunter ivory hunter is offline
Sportster/Buell Model: 1200N
Sportster/Buell Model #2: FXSTB
Other Motorcycle Model: Buell S1
Other Motorcycle Year: 1998
ivory hunter is an unknown quantity at this point
Dude that sucks
Maby a used primary on Egay is the cheeper way
I had the head strip out on one removing it.
I have NO idea how it got so tight without it tearing the threads out of the aluminum.
Old 3rd April 2009
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
Dude,That sucks. However If you followed the torque specs from HD there must have been a defect in the casting. If the dealer dont help you Call HD customer service !
It likely had a casting defect right at the thread boss. You could fix it but Why should you ?/ Make them give you a new cover..
Old 3rd April 2009
ReddTigger's Avatar
I've NEVER used a torque wrench on something that small. and I have never had a problem. Sorry, but anything under 20 lb foot, I use my wrist.
States I've Ridden in
71.3 hp 70.8 tq
Old 3rd April 2009
Senior Bike Builder
You got a number for customer service?
I've seen it before, but can't remember the thread...
Old 3rd April 2009
PatGoFast's Avatar
PatGoFast PatGoFast is offline
Sportster/Buell Model: XL883L
PatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the roughPatGoFast is a jewel in the rough
Actualy, A torque wrench is not acurate that low in the scale. I don't think it is a defect in the casting of any kind. A Torque Wrench that reads in ft.lbs. was never intended to be used at the 10lb. setting. It should be in the manual for the wrench. Sorry about the misfortune anyway. Is there room for a heli-coil?
Old 3rd April 2009
PatGoFast's Avatar
Red beat me to the punch
Old 3rd April 2009
Senior Bike Builder
The torque wrench I'm using is rated for 5-85 ft-lbs. If it's not accurate that low, then I'm calling Craftsman to get the primary cover paid for. The wrench is only a couple weeks old.
Old 3rd April 2009
milmat1's Avatar
Harley-Davidson Customer Service
3700 W. Juneau Avenue
Milwaukee, WI 53208
To speak with a Harley-Davidson customer service representative call (414) 343-4056.
CLICKYHERE
