0 33.4mm fork/hub issues
Last Post: Seeny
0 Safe Max Rev Limit stock engine Roadster 2017
0 Call the new 2020 models Sportsters?
Last Post: sportyone
0 73 Ironhead
Last Post: 72 Ironhead XLH
0 Misfire 02 883
0 headlight upgrade
Last Post: Nrg2brn
Last Post: oupa
0 Early Ironhead oil cooler? Filter upgrade?
Last Post: curiousgeorge
Last Post: motorend
2 Humble pie
Last Post: mac93
0 My 1250 to 1275 build
Last Post: Bryan1976
0 EFI 101 Thread
Last Post: Turbo Sporty 48
0 Ran out of gas.
Last Post: Calcustom
0 Amputee Sporty Springer Trike Conversion
10 waited all year for this moment its on!!
5 Favourite grips?
Last Post: Jason's Sporty
0 Weight reduction TRUTH, not fiction
0 is a buell a harley
Last Post: Crash7557
0 Flat tracker pics
Last Post: Gary E
0 Clutch Spring plate poll
0 Helping a friend...
Last Post: MDT
0 old member new thoughts
Last Post: clif02
0 Ever been pulled over?
Last Post: Sprtstr1200s
Old 15th February 2007
sportstermike sportstermike is offline
Sportster/Buell Model: 1200c
sportstermike has disabled reputation
Default 2001 Electrical wiring
I am currently rebuilding my 2001C from the ground up. I have done alot of work on the electrial in the past getting rid of blinkers and removing fender tail light and things like that. Though that experience I have learned one thing....HARLEY WIRING IS A CLUSTER !!!!! My question is does anyone know where I can find a bare bones electrical schematic or someone who can create one for a 2001C. By bare bones I mean just what I need to power headlight, battery, horn, starter things like that. No harnesess, blinkers and misc. wiring that Harley seems to put on their bikes. ANY help would be good help. Thanks in advance guys!
Sportster Mike
Casper's Avatar
Casper Casper is offline
BT Heathen
Sportster/Buell Model: FLHTPI
Casper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to beholdCasper is a splendid one to behold
I doubt you'll find a bare bones wiring schematic. My recommendation would be to get your hands on a repair manual (H-D, Clymer, etc.), scan the diagram into your computer, and just use something like Paint to edit out the wires you don't want. Then print it, and there you are. That way you can ensure the accuracy of the diagram, you have the exact components you want, and nothing else (plus, if you keep the original scan, you can always go back and redo it if you decide you want to add other electrical components later).
I know it's probably not the answer you were looking for, but I'd be a little skeptical of taking any homemade wiring diagrams from strangers as gospel, and (I'm sure for legal reasons) no corporately published manual is going to eliminate things like turn signals from their diagrams.
That's just my 2¢.
I need more Plan B's in my life. Plan A rarely works as advertised.
Thanks Casper, Thats not a bad idea. When it comes to mechanical aspects of my bike im on it but electrical or even house electrical for that matter I'm like a deer caught in the headlights!
indyrednek's Avatar
indyrednek indyrednek is offline
Sportster/Buell Model: 883c
Sportster/Buell Model #2: Flyrite Rigid completed?
indyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the rough
I have an '03 HD manual. If you have a fax# I can make diagram copies and fax them.
PM me if you have a fax#.
Old 16th February 2007
Moved On Moved On is offline
This is the entire harness for a 2003 (2001 is identicle), but all of the
unecessary stuff is shaded out in green... When I drew this up the guy that
asked for it was not going to run the engine switch on the handle bar, thus the
note in the middle about tieing the gray and white/black wires together. If you
are going to have an engine switch then don't tie them put the switch between
them instead. The diagram still looks comples, but if you concentrate on the
stuff not shaded in green you'll see that there really isn't too much wiring left
over.
Gazza
sdjr sdjr is offline
Sportster/Buell Model: xl 883->1200
sdjr will become famous soon enoughsdjr will become famous soon enoughsdjr will become famous soon enoughsdjr will become famous soon enoughsdjr will become famous soon enoughsdjr will become famous soon enoughsdjr will become famous soon enough
GARY, great job on the schematic...JR
John
San Diego
1999 XLH ^1200, Black
buell thunderstorm heads/pistons,
progressive springs/shocks, S&S AC
cycleshack slip- ons, SE Ignition/Cams
Diamond Back cables, internal wires
Mustang Vintage Wide Seat
Metzler 880's 110 upfront, 150 in the rear
I was just looking at that more and you could also ditch the
starter relay if you went with a high amperage momentary
toggle switch or better yet one of the push button switches
that mount to the end of the solenoid (J&P has then for $40).
Gazza
Gary, You rock man. Actually I was wanting to go with a push button or toggle switch. This is what I was looking for. Thanks for taking the time to scan that schematic. Nice to know there are brothers out there willing to help out!
Thanks to you to Indyrednek. Hope I can help you out one day
No problem... just for clarification though, that diagram is not
a scan I drew it myself in Protel CAD, so it's not burdened by
factory copyrights.
Gazza
