0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Old 18th February 2007
jefyjay's Avatar
jefyjay jefyjay is offline
jefyjay has disabled reputation
Default Primary temp?
I have a 74 Ironhead and I was just wondering how hot the primary cover gets on your ironhead? Just reach down next time you ride and let me know if its warm, hot, or hotter than sh#$!! thanx jeff
Kozak's Avatar
Kozak Kozak is offline
Sportster/Buell Year: 1982
Kozak is on a distinguished roadKozak is on a distinguished roadKozak is on a distinguished road
Wow, with temps in the 20's it'll be awhile.
1982 Ironhead
Old 19th February 2007
Never noticed a heat problem with the p cover. But i can burn my leg on the oil tank, even with an oil cooler running.
Matt Matt is offline
Riding with Angels
Sportster/Buell Year: 1968
Matt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the rough
I think people feel pain at about 160* F. That's not real warm for a primary cover.
Matt
dabronco's Avatar
dabronco dabronco is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH (ironhead)
Sportster/Buell Year: '77
Other Motorcycle Model: Sold it!!
dabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura about
I don't think most of the heat in the primary is generated there. It migrates from the business side of the engine.
Murphy is my co-pilot.
jefyjay's Avatar
Ok, so let me explain what happened! I was riding a few days ago and got the bike very hot in traffic. Once I hit the open road I took off and it started to bog down so I pulled over and the oil level was very high!( to the top of my horseshoe tank) So I dumped out a little and rode the rest of the way home. I reached down and touched the primary for the first time and it was hotter than sh#$!! If the oil gets too full in the tank and the top two oil lines are submerged, where does the oil go??? I hope this run-on sentence makes sence.....jeff
dabronco's Avatar
I would check to see if the pressure side of yer oil pump is working. Pull one of your rocker plugs and see if oil pumps out while cranking. As for your primary, how's the oil level?
Old 20th February 2007
Two possibilities:
On some years of the older ironheads there is a connection between the engine oil and primary oil; they can mix in there.
Is it possible you added engine oil thinking it was low when in fact it was at the correct level? When a bike sits for a while the oil migrates past the oil pump check valve and appears to be low, but it not.
