0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
7 Long Road Trip advice
Last Post: gunwish
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
0 79-83 dual disc fork spring length
Last Post: Reverend G
Old 18th February 2007
jeeplite's Avatar
jeeplite jeeplite is offline
Sportster/Buell Model: xl 883
Sportster/Buell Model #2: Springer Classic
Other Motorcycle Model: Concours 14
Other Motorcycle Year: 2008
jeeplite has disabled reputation
Default Headlight fairing vs. 3/4 fairing or larger
I have the headlight fairing and while providing a nice "hood" for my speedo an tach, not diverting any wind off the head(hemet). Over 70mph and strain on the neck sets in. I like the cafe look so I won't be going to the big flat and clear windshield although I would like to know if it blocks hemet buffeting? Does anyone out there have the 3/4 and how does it work for you?
Old 19th February 2007
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
If you mean this one....HD calls it a 1/4 fairing. It does a great job at highway and above speeds. Makes the high speed (70 and Up) much nicer!
http://memimage.cardomain.net/member...50_54_full.jpg
http://memimage.cardomain.net/member...50_69_full.jpg
Stuff: YES
bikerbill bikerbill is offline
bikerbill has disabled reputation
Omar makes a nice 1/4 fairing, however, will need to go to a 7 or 8 inch headlight. I think by typing in Omar's vintage fairings will get you the site. Also may try airtech site.
jeeplite's Avatar
Yes, thats the one, looks like a great touring screen. The headlight fairing I have was called "Rocketeer" on the labeling.
The 1/4 fairing (not 3/4 fairing, I mis-spoke) doesn't look as bulky as I could see from the catalog pictures, looks like a good 4 to 5 inches higher than mine. Perfect, good look that sheds the wind, thanks.
AZbiker's Avatar
AZbiker AZbiker is offline
Sportster/Buell Model: xlh883
AZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished roadAZbiker is on a distinguished road
For comfort on long trips, try this: Put your feet on the passenger pegs and tilt your torso forward. Let the wind hold your head up and relax your neck muscles. The wind will bounce your head around a little bit, but I don't think it's a big deal. It sounds to me like you're trying to fight the wind.
Gone Gone is offline
The H-D 1/4 fairing also allows for the windscreen to be raised a little bit, through the use of a second set of mounting holes. Coupled with a slightly lower bar, it can make quite a difference in highway protection. Quick disconnect docking clamps allow for removal or installation in seconds.
snowman's Avatar
snowman snowman is offline
I'm in the process of adding the Ness fairing.....
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 20th February 2007
I saw a Sportster, or perhaps a Dyna with an old Vetters Phantom faring, if you are not familiar with the Phantom do a Google search on it.
Anyway, the bike looked fantastic. Don't believe you'd ever find one today, they didn't make many of them. Back in the early 70s I was fortunate enough to run across one that I put on a Norton.
But I gotta tell you a fairing on a sportster just doesn't sound right, I have a quick release windshield that I use at particular times during the year. It ain't perfect but it has its moments.
Old 21st February 2007
Default Vetter Phantom Fairing
I found a picture of that Vetter Phanton Fairing
Grumpy's Avatar
Grumpy Grumpy is offline
Grumpy will become famous soon enoughGrumpy will become famous soon enoughGrumpy will become famous soon enoughGrumpy will become famous soon enoughGrumpy will become famous soon enoughGrumpy will become famous soon enough
That Vetter fairing looks good.
