Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 21st February 2007
wildwill8's Avatar
wildwill8 wildwill8 is offline
Sportster/Buell Model: 06 Redneck Mutant
wildwill8 is on a distinguished roadwildwill8 is on a distinguished roadwildwill8 is on a distinguished road
Default No run just loud back fire
Ok trying fire up my mutant for the 1st time I installed new cams 1250 kit and heads running a crane hi 4 race and all I am getting is a Loud back fire out the pipe I have set up the time and few times thinking that it was off pulled the cam cover off think the cams off but they are lined up thought maybe it was a 180 off but move the wire around did not help so Now I am stuck Helppppppppppppppppp
Here is a pic of the cams
snowman's Avatar
snowman snowman is offline
bumpin' you back up for some help.....
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
rottenralph's Avatar
Aren't you using a s&s. need some carb info.
Hi.
I would put the cam cover back on and do a compression test.
ASSUMING it checks out ok, then you need to look at the Ignition, it is either out of time or defective.
Unless you have the spark plug wires on Backwards.
(That's what I have my money on.)
wildwill8's Avatar
Here is what I have done Check for spark got spark thought maybe I had the plug wire on backward changed them around geting fuel cuase she shots a big blue flame out the pipe I am going put it back togetter tomorrow I broke the gasket so got to get a new one and I am going to check the compresson I got the rockers back on the see if it has compreeson I check it with out the vavles opening and it is working that away so I get get the rockers back on and let you know from their. and RR I am running a Super E carb.
wildwill8's Avatar
Ok I just put on the rear rocker back on and I am not getting any compreeson the gage I have does not got very low it start read around 25 but when I hit the button the release the PSI I can hear any thing.
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
I could be wrong but I think the Buell cams are clocked different from the Sportster for some reason. Did you get Buell specific cams ?? I think I read it on the NRHS site, I'll see if I can find it.
My Other Toy Goes Mach 25
wildwill8's Avatar
them motor is a 95 buell but it is the samething as the sporty motor for that year.
HDandME's Avatar
HDandME HDandME is offline
HDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enough
Only places pressure can escape is out the valves or past the rings.
Check valve seats possibly? Did you visually watch the engine go through all 4 cycles? IE, set piston at TDC, watch intake open as piston drops,etc etc. I don't know much about the harley engines specifically, but generally speaking on motors, there really isn't a huge list that would cause 0 compression. Especially after a fresh build.
Good luck
.295 .68 should be about right on the jetting. Choke it full to start.
