0 Value of a Boattail?
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Old 25th February 2007
joestuff's Avatar
joestuff joestuff is offline
Sportster/Buell Model: XLCH, restored
Sportster/Buell Model #2: XLH, period hotrod basket
Sportster/Buell Year #2: 1961
Other Motorcycle Model: FXDXT (T-sport)
Other Motorcycle Year: 2002
joestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the roughjoestuff is a jewel in the rough
Default Stupid rear brake question
So I'm used to disk brakes on a dyna glide, I put new rear brakes on the 62 xlch, and everything is adjust correctlly as per manual. But it does not seem right, the pedal seems to move to far. I cannot rotate my foot enough to get full pressure on the brake with my foot on the peg. It seems I will have to take my foot off the peg and use my heel on the pedal to get enough pressure to get some real brake action. Is this just the way it is on the older drum brakes, or should I revist my brake job.
Thanks
Joe
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
Did you center the shoes using the pivot stud?
Also, the rear brakes can be adjusted by backing off the rod's adjuster nut and then jumping the brake pedal up one tooth on the cross linkage.
SEMJPM
Old 26th February 2007
ironhead red's Avatar
ironhead red ironhead red is offline
Sportster/Buell Model: XLCH Stroker Chop
Sportster/Buell Model #2: XLH Bobber
Sportster/Buell Year #2: 1977
Other Motorcycle Model: XLH Project ?????
Other Motorcycle Year: 1980
ironhead red has disabled reputation
A drum will never perform like a good disc brake setup, but with proper adjustments, it should work just fine. Alot of big twin drum brakes were hydraulic so they typically worked better than the mechanical sporties. Good luck.
Red
