0 Nup 1009 (Bearing)
0 S&S Super E Carb
Last Post: jp2code
Last Post: 77IRHD
Last Post: retread08
Last Post: JacksBrother
0 New to me 55kh
Last Post: jp2code
Last Post: mikethebike61
0 so it's officially ended
0 AGM battery for 76' XLH
Last Post: forqueue
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Nitro57xl
Last Post: Cablejudge
0 Sportster book
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: Nicktater
0 What jets do you use?
Last Post: Thack
5 Red Shift cams similar to Jackhammer 570 ?
View Poll Results: Is this the cure for the dreaded ECM relocation??
Brilliant!!!!....this is exactly what I was looking for! 62 91.18%
Looks good but not functional 3 4.41%
This doesn't solve anything 3 4.41%
Voters: 68. You may not vote on this poll
Old 17th April 2009
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Default Cosmo's ECM Relocation Mod
Well boys and girls....I must say I am very excited on my new find. As some of you may know from my other thread, I am in the process of tearing down, rewiring and rebuilding my 07' 1200N (http://xlforum.net/forums/s...d.php?t=466630). One of my goals is to run an 06' rear fender with a 06' Lepera Bare Bones seat. In order to do this I have to relocate the dreaded ECM.
Well I think I have the answer many might be waiting for 07'+ sporty's. I thought of a few places to put the ECM....like place it in a weatherproof box and mount it under the tranny between the frame rails or above the tranny above the starter. The more I looked at the bike with the motor installed and the position of the ECM above the starter it kinda defeated my purpose of rewiring the bike and keeping the area clear around the engine.
Someone else had placed the ECM under the battery cover, but what I didn't like was the fact that the cover would not close like it normally did and it stuck out further than the oil cover side. So I started playing around. I was getting interference between the battery cover and the mounted ECM. So I decided to modify the ECM. I cut two of the mounting posts off so that I could suck the ECM up under the lip of the oil tank. This helped a lot. I was only about 1/8-1/4" off from being back to normal.
So I pondered the situation...pulling the battery in and out...and the battery tray...the ECM...closing and opening the battery cover atleast a hundred times. Then it hit me. The battery! On the throttle side of the bike it is captured by the oil tank BUT the battery tray itself keeps the battery from hitting the tank. I pulled out the battery tray and cut the back strap and side off:
Here is a pic of the battery in the tray and you can see now it can slide past the edge:
My plan is to make a new strap that will hold both the battery and ECM to the tray. Here is a picture of the modified ECM. You can see the 2 mounting posts that I cut off and the fins that I removed:
Here are some pics of the battery and ECM taped together while I was doing the "fitting". You can see why I cut off the mounting posts on the ECM better here to allow me to move it up as far as possible under the oil tank and the fins and bottom posts for clearance to the battery cover:
Here are some pics of the cover closed....looks like it did when I first bought it:
Maybe it is just me but I am super excited about this. I know now that I can keep the entire area around my engine as clean as possible. What do you think???
Cosmo
Old 18th April 2009
Tike71's Avatar
Tike71 Tike71 is offline
Sportster/Buell Model: 883 Iron
Tike71 will become famous soon enoughTike71 will become famous soon enoughTike71 will become famous soon enoughTike71 will become famous soon enoughTike71 will become famous soon enoughTike71 will become famous soon enoughTike71 will become famous soon enough
That right there is genius. Can't wait to see the finished project.
Old 18th April 2009
08nightmare's Avatar
08nightmare 08nightmare is offline
Sportster/Buell Model #2: Nightster
Sportster/Buell Year #2: 2008
08nightmare is an unknown quantity at this point
nice!! weatherproof, free, and still looks clean!
- Spending a Life Sentence Behind Bars -
Old 18th April 2009
BgrMaine's Avatar
BgrMaine BgrMaine is offline
BgrMaine is on a distinguished roadBgrMaine is on a distinguished roadBgrMaine is on a distinguished road
Great job. That's good thinking. I've been thinking on this for a while now, trying to figure out how to get it down there without having the cover stick out. You've got the solution. Thanks for doing all the heavy thinking!
2007 XL1200R
Old 18th April 2009
Thanks guys....appreciate it.
It just dawned on me though....I've relocated my fuse blocks and crap that currently sits under the battery cover....so I wonder if this would work with the stock 07' wiring set-up? I think it is far enough back that it would clear the fuse blocks.
My excitement is that this was a big hold up on finishing up my wiring to the ECM/fuse blocks/TSM. I am also running a V&H Fuel Pak...from what I see I have a couple options for mounting it (would have more if I didn't relocate my ignition switch where I did...but I prefer my new ignition switch location) so it is just a matter of finalizing that and getting closer to getting the bike back on the road!
Old 18th April 2009
Brad Brad is offline
Sportster/Buell Year: None
Don't have an ECM, but if I did, this would be the solution for me! ~ awesome!
Have some 'nanners!
Old 18th April 2009
snowman's Avatar
snowman snowman is offline
Will there be any issues with heat? Will you still have some airflow in there by the oil tank?
Maybe a slot in the cover with some cool mesh?
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 18th April 2009
Russ, yeah air flow around the oil tank was a concern but after I made the mod the only part of the battery actually touching the oil tank is the upper edge. There is about 1/8" clearance just below that top rim of the battery and then it opens up as you go down to the bottom of the battery to I would say 1/4" or a little more.
Edit:
Just thought of something else, I have removed the large plastic piece that goes around the frame just in front of the battery (holds some wires, fuse blocks, etc) and the wires so I have essentially increased air flow to behind the oil tank cover.
Old 18th April 2009
snowman's Avatar
Edit:
Excellent!!!!
Old 18th April 2009
Excellent!!!!
Just a follow-up...here is a pic looking from the rear cylinder back towards the oil tank (pic is a little blurry because it was a pretty tight shot):
You can see what I was talking about as far as it touching just at the top of the battery and the clearance between the battery and oil tank. It doesn't look like it touches from this angle, but the lip you see on the oil tank slants towards the ground as you go further to the back of the bike.
The only wire I'll have coming through here will be the negative wire coming from the negative lug on the battery that you can see in the pic. So I should have an increase in air-flow through this area.
