0 Paulie420 needs your help.
Last Post: Jowniofownio
0 Not charging issue!
0 Value of a Boattail?
Last Post: Moon Wolf
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
Old 19th April 2009
RanterL RanterL is offline
RanterL is an unknown quantity at this point
Default Manifold problem
Just got a S&S super E kit to replace my crapped out Bendix and now im have intake manifold leaks! Ive jiggled around with it but cant quite get it to seal right? Is there a trick to this?
Old 19th April 2009
IronHead78's Avatar
IronHead78 IronHead78 is offline
Sportster/Buell Year: 78
IronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura about
Lossen up your heads, this will allow them to move just a tad.Now install the manifold with the carb,(for me it helps to get it seated with the carb bolted to the manifold) move the heads a little until you have a good seal. Wrap a couple turns of electrical tape over the joint over the o-ring (helps it seal, don't worry it won't melt) Clamp it down then retighten tighten your heads. Oh yeah if you can grow a third hand or get a helper it makes life easier'
Sometimes you have to lossen the jugs also but most of the time you'll get enough play by just working with the heads. Good luck
Old 19th April 2009
Thanx. Ill ive it a shot
Old 19th April 2009
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Put late model - 79 onwards - rubber hose manifold seals on over top of the o-rings. Then put those t-bar stainless steel aircraft type clamps over the late rubbers.
This has kept mine sealed good for the past 10,000 miles.
Old 19th April 2009
Thanks for the info. Ill try this if I cant get it to work the conventional way.
