0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
Last Post: sevenyears of famine
Last Post: friday
Last Post: guitarfish
0 oil pouring out on right side
Last Post: blindfredy
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
0 switched 12V
Last Post: conv90
Old 28th March 2005
jag1 jag1 is offline
jag1 has disabled reputation
Default overfill oil leak
O.K. I'm going crazy here. I've got an '04 883 Custom and I just got it out from winter storage. I took it for a ride and parked it back in the garage and noticed a couple of drips on the floor. Ever since I've been trying to figure out where it's been coming from. I drained some oil out and took it for another short ride and checked again and no drips. So, who has filled there oil tank too full and had a leak? Where does the leak come from?
Old 28th March 2005
jmhurt jmhurt is offline
jmhurt has disabled reputation
Hey I've been experiencing the same thing. I got my '04 1200R in
October, it had a slight leak at the dealership when I bought it,
coming from the left side. The tech said it had been overfilled , as
opposed to the '03-earlier models (they would blow the dipstick out).
I got it out of storage this week (finally warm) and looked it over...
Sure enough, small puddle underneath left side. Inside of battery cover
has oil on it. The oil also trailed down the oil tank, ran down the drain
a hose and covered the rear brake master cylinder cover. Best I can tell its coming from the top of the oil tank, rear left corner where the top is pressed
into the bottom half of the tank...maybe a gasket leak? Either way, even if
it is overfilled, the tank shouldn't just let oil run out all over the place.
Old 28th March 2005
Turbota's Avatar
Turbota Turbota is offline
Jag ...
How much oil are you putting into it?
The 04-05 1200s will only take 3 quarts [total] with an oil filter change. I doubt the 883 is any different.
If your putting more than that in it .... Your putting in too much oil.
04 XL 1222R
Old 28th March 2005
dwardy dwardy is offline
Sportster/Buell Model: '92 883/1200
dwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished roaddwardy is on a distinguished road
It usually comes out the breather holes, into your air cleaner, and drips all over everything, unless you have a breather kit installed. Then, it would just drip out of the breather drain hose. I think most people are keeping their level down close to the lower mark to keep that from happening.
Old 29th March 2005
It's not overfilled, I checked it last knight after a long ride and the oil is halfway on the dipstick. I think it's actualy comeing from the oil filter. I noticed last night it was dripping up by the gasket and running down the front of the motor back to that block that the rear master cylinder bolts to. So, I guess I'll chang the filter and do see if that solves it. Man, I hate leaks. Thanks Guys
Old 29th March 2005
decman decman is online now
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Also check the oil sending unit, they leak a lot.
The oil blows back when you ride so it may look
like it come from somplace else.
I thought my pushrod seals were leaking for a while.
Similar Threads
Once ... twice ... three times a rocker cover oil leak RSK Sportster Motorcycle Motor - Top End 7 12th March 2008 01:07
Found Last Year's Oil Leak! IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 11 7th November 2005 05:56
Rocker cover oil leak for the fourth time; need advice RSK Sportster Motorcycle Motor - Top End 35 21st August 2005 03:03
Exhaust leak = Carb farts? DM-SC Sportster Motorcycle General Discussion and Problems 3 15th May 2005 01:29
Rubbermount oil leak poll... MacDuff Rubber Mount Sportster Motorcycle Talk (2004-2006) 68 12th May 2005 03:58
