Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 17th March 2007
Massdog05's Avatar
Massdog05 Massdog05 is offline
Massdog05 has disabled reputation
Question Exhaust Flanges
So my bike came with drags. They used the flanges from the orignal pipes for the drags. Now how do I get the flanges back on the stock pipes to put them back on when I do the gronk mod? Orignal exhaust wasn't ground down or anything, so I can't see how they got them off in the first place, let alone how I'm gonna get them back on and how they will hold the pipes in.
1999 XL1200S,
Performance: 05 1200C Heads Dual-Plugged, SE 7500RPM Ignition Module, Andrews N8's, SE A/C & High-Flow Filter, Port-Matched Intake Manifold, Homemade Breather Kit, Thunderheader Exhaust, High Flow Petcock,
Aesthetic: black motor, wide-glide 39mm triple trees, braided stainless lines, 1200L handlebars w/ internal wiring, Corbin Dual-Tour with driver backrest, sissy bar/pad, HD bullet turn signals, bottom mount headlight, HD teardrop mirrors, mid controls with highway pegs, o-ring pegs, turn signal relocation bar, Kuryakyn R.B.T. module, homemade lay down license plate, high output horn & 1200C cover, l-to-r derby cover,
Old 17th March 2007
pres41's Avatar
pres41 pres41 is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Wifes 883 Custom
pres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the rough
Massdog:
There is a snap ring that allows the flange to come off the pipe, pull the flange back toward the pipe end and the snap ring should come out of the flange and also you will see the ridge on the head end of the pipe where the snap ring seats.
Pete
2002 "883" (Taxes paid and then some) <G>
Progressive up front, RK air shocks out back
Super Low Bars, and Whats a Harley without bling
Old 17th March 2007
DC in PHX DC in PHX is offline
Senior Master Bike Builder
DC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really niceDC in PHX is just really nice
Yup, and wear safety glasses when you do it. You will find out why
DC
Old 17th March 2007
Rob Henderson's Avatar
Rob Henderson Rob Henderson is offline
Sportster/Buell Model: XL883/1200C
Sportster/Buell Year: 03
Sportster/Buell Model #2: FLSTF FATBOY
Sportster/Buell Year #2: 07
Rob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura about
I just clipped a small set of vise grips on one end or the clip....That kept the clip from flying across the way.
2003 XL883/1200C
Ceramic Bassani Sweepers, Forcewinder A/C, SE IGN, Wiseco 9.5.1, S&S Super E, Progressive 412's etc. etc, etc.
No More sporty......2007 FLSTF - FATBOY - I am a traitor!
Old 17th March 2007
Massdog05's Avatar
Thanks, I just wanted to make sure that I wouldn't have to get something else before making the swap.
