Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
0 Solar battery charging
Last Post: tvon
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
0 Hello from Toronto, Canada!
Last Post: Veeflys
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Old 17th March 2007
addy76 addy76 is offline
Sportster/Buell Model: 883 Sportster
addy76 is an unknown quantity at this point
Default Oil Light Problem!!!!
I just got back from riding and my oil light flashed off and on and then wouldn't come on at all and when I turned my key to the off position and then back on and the oil light wouldn't come on. Then when I shake my bike up and down the light flashes. What could be the problem or problems that it could be? It is a 2006 XL883 Custom. Any info would be helpful!!!!
Old 17th March 2007
Moved On Moved On is offline
Probably sensor going bad. They are crappy sensors and need replacement often. They run about $15 for a sensor and maybe half hour labor to change. Check the connections first though. It could be a loose wire also.
Gazza
Old 17th March 2007
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
Gazza
I agree. The same thing happened to mine...
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Old 17th March 2007
davidcar's Avatar
davidcar davidcar is offline
davidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura aboutdavidcar has a spectacular aura about
Default yep what he said
yep I would check the wires, maybe oil or a film of corrosion on the connection bad connection fitting, etc.
Gazza
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
Old 17th March 2007
Stratdaddy's Avatar
Stratdaddy Stratdaddy is offline
Stratdaddy is an unknown quantity at this point
Cool Oil Pressure Light
Same problem on my '03 1200 XLH. It happened at about 700 miles, it's come on 2 times since then (in 2000 mi.) but as long as the oil pumps and lubes the motor it's not a problem. Either a bad sensor or bad connection. I bought my Sporty last July with 350 miles on it in "new" condition. Not very many bad oil pumps with this little wear.
