Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 New member in MD
Last Post: ReddTigger
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 Help me with gas cap...
0 Sportster or Street Bob
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 1968 XLCH Oil Leak
Last Post: 72 Ironhead XLH
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
0 Drive Chain Adjustment
Last Post: class of 82
Last Post: RKN
Old 20th March 2007
XLFREAK XLFREAK is offline
Default what would happen??
if you were to drop a lil debree into the motor if you were taking the pistons off???..........just a lil bit.......or if the some tiny lil strings from the rags stuffed on top of the flywheel stayed in there???
Old 21st March 2007
Everett's Avatar
Everett Everett is offline
Sportster/Buell Year: 1988
Everett is an unknown quantity at this point
im no master mechanic, but i dont think a touch of schmeg from a rag would do anything bad. im sure it would end up burning up or coming out one way or another. depends on what ya drop.... a nickel or some dusty grime off a rag.
Old 21st March 2007
well i guess the rag was a dumb example...but like even a lil drop of carbon debree from a piston?
Old 21st March 2007
Matt Matt is offline
Riding with Angels
Sportster/Buell Year: 1968
Matt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the roughMatt is a jewel in the rough
That's what filters are for. You'll be changing oil anyway after the build right?
Don't worry about it, if threads from a shop rag caused problems they'd be made out of something else.
Matt
Old 21st March 2007
oh yea ill be changing the oil and transmission oil before i start her up for the first time....
Old 21st March 2007
sporty58's Avatar
sporty58 sporty58 is offline
Sportster/Buell Model #2: XLH QC99
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Dyna
Other Motorcycle Year: 2009
sporty58 has disabled reputation
I generally use newer rags around there to try to avoid that. The most common thing to drop is probably the circlip that holds the wrist pin in either when you are taking the old one out or putting the new one in... It is a real good idea to make sure you have rags stuffed in there tight before you mess with them... (Unless you are looking for an excuse to go to the 88". (Shit hon.. It fell in...... so as long as i have to split the cases I might just as well have NRHS bore the cases and go with 88"... It is almost the same price)
2005 - 1212 conversion, Stage III NRHS Heads, S$S .600 cams, Krome Werks slip ons, Twin Tec ignition, HSR45, Hurricane on DevonatorII
1998 - 99" homegrown conversion, Stage II NRHS Thunderstorm heads, Redshift .643 cams, Axtell castiron cylinders, S$S 4 5/16 crank, S&S G with thunderjet
** Gone** 2004 R1150R.... Just had to try one and the ride sucked so bad I sold it after one season... pretty bad when it is a worse ride than a solid mount sporty
Old 21st March 2007
so the lil shit wont hurt the engine really...espwecially if im doing oil changes before i fire her up
