Last Post: roadsterboy
Last Post: Airbozo
Last Post: _Outlaw
Last Post: mor
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
crack, sprocked cover
Old 10th May 2009
mandaltby's Avatar
mandaltby mandaltby is offline
Sportster/Buell Model: 82 xls 1000
Sportster/Buell Year: 1982
mandaltby is on a distinguished roadmandaltby is on a distinguished roadmandaltby is on a distinguished road
Default cracked sprocked cover
Bike fell of Jack, and I noticed a small crack, 3/4" above the brake pedal mount. Im looking for a new cover on Ebay. How serious is this. Ive seen Sportys with this cover removed I think. What does the community think? I dont think there is any liquid to flow out of there. I should be cool for a wek or two till Im able to find one right?
http://picasaweb.google.com/dan.maltby/BackFromRebuild#5388709149769213666
82 xls Roadster/Andrews PB+ Cams/S&S Super E / drag pipes/ 2"baffles/exhaust wrap
None are more hopelessly enslaved than those who falsely believe they are free!
Old 10th May 2009
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
I think the same cover fits 82-90. Here's a new one for $36
http://www.retrocycle.com/CustomChro...odels.html#top
Old 10th May 2009
The sprocket cover, unlike the gearcase and primary covers, is just a cover. It provides support for the kicker system on XLCHs. On the XLHs it is just "there". Perhaps keeps your pant leg from getting into the chain. Perhaps a little weld underneath is all that it needs.
Old 10th May 2009
1976 XL's Avatar
1976 XL 1976 XL is offline
Sportster/Buell Model: Sportster XL
Sportster/Buell Year: 1976
Other Motorcycle Model: Springer Softtail
Other Motorcycle Year: 89'
1976 XL is on a distinguished road1976 XL is on a distinguished road
I Laid Mine Over A While Back, And Broke My Cam Cover Just Behind The The Oil Chamber. I Took It To Our Local Tech School( They Have Alot Of Tools ) And Had It Heli-arc Welded. It Didn't Warp My Cover But It's Not Very Pretty. Although I Can Buy A Chrome Tin Cover To Go Over The Cam Cover , I Don't Think They Make Them For The Sprocket Cover, But You Can Have It Welded.
Old 11th May 2009
mandaltby's Avatar
Default Cracked Sprocket cover
Hey Bikenut thanks man, that Retro Cycle place is kick ass. I ordered the new sprocket, and I got to be more careful with putting bike on the jack. I just balanced bike on jack, I need to use straps all the time.
Old 11th May 2009
Originally Posted by mandaltby View Post
... I just balanced bike on jack, I need to use straps all the time.
I use 4 straps, two at front forks, two at passenger footpegs. Takes me a good 10 minutes to set up to use the lift. But i had a near miss one time, almost lost it.
Old 11th May 2009
mandaltby's Avatar
Red face no short cuts
Thank god thats all that broke
from now on I will always take the time and strap her all up
like anything else
the short cut turned into the costly $$$$ long way around
but its ok, I been meaning to clean out the whole sprocket area since i fixed the leak in the oil tank, which was spraying oil over that whole area for years
