Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
Old 18th May 2009
risotteria's Avatar
risotteria risotteria is offline
Sportster/Buell Model: 1200xl
Sportster/Buell Model #2: 1966 mustang 302hipo
Other Motorcycle Model: sporty in pieces
risotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the roughrisotteria is a jewel in the rough
go to home depot and get a screw stripped remover (or some such shit) drill bit they remove all problem torx
Old 18th May 2009
tfarmer49's Avatar
tfarmer49 tfarmer49 is offline
Sportster/Buell Model: 1200L
tfarmer49 has disabled reputation
Just went through this myself. Timing chain inspection cover was leaking. A wise forumite suggested replacing the cheesy rubber gasket with the paper/metal sandwich one. Part # 34761-04A. The $2 gasket came in a kit with the gasket and slightly redesigned inspection cover. $23 - ouch. While I was at it I decided to change the tranny/primary fluid to Red Line 75/90. The derby cover gasket had me stressed out until I put a little permatex on the back of it to hold it in place. I then tried torqueing the torx 27s in accordance with the manual. Two of them stripped (the torx heads, not the threads) before I reached the torque. Grrrrrrrrrr. I went and bought some 1/4 -20 allen head machine screws and replaced all six cause I was worried about uneven torque on the derby cover. This time I let the torque wrench sit and torqued them all by feel with the allen wrench. Now I'm happy. My sporty's got new oil, the oil is staying inside the case, and I'm satisfied My primary/tranny will be good for another 4000 miles or so.
Old 26th September 2011
blackandtan21 blackandtan21 is offline
blackandtan21 is an unknown quantity at this point
I was able to pop the stuck torx bolts off by dremeling a slot into them and then placing a screwdriver into the slot and tapping with a hammer. When I buttoned everything up I used engine assembly oil to keep the derby cover o-ring in place. This seemed to work great.
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
Blue Loctite is your friend!!! And dont spare it either.
http://xlforum.net/forums/showthread.php?t=842245
Old 3rd October 2011
SFRoadster's Avatar
SFRoadster SFRoadster is offline
Sportster/Buell Model: XL 1200R
SFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really niceSFRoadster is just really nice
Just had the same experience with a stripped Torx screw on the derby cover. Didn't tilt the bike upright so I lost a couple of ounces of fluid. My new Rule #1: Check the Forum before starting any project. Duh!
PilotCrabby's Avatar
PilotCrabby PilotCrabby is offline
Other Motorcycle Model: Kawasaki Ninja ZX6R
PilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to allPilotCrabby is a name known to all
Hmmm just took the Derby cover, Timing chain inspection plate, Primary cover, and the crankcase cover. I only messed up on bolt, but I managed to strip the threads on the bottom derby cover bolt.
