0 1967 XLCH stroker project
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 New to Harley
0 79 ironhead
0 THE Trainspotting Thread
0 rpm jump pulling in clutch
0 Need help with glare.
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
0 Value of a Boattail?
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
Last Post: jammantoo
Last Post: lugster
Old 15th May 2009
Redrocker's Avatar
Redrocker Redrocker is offline
Sportster/Buell Model: 2004 Sportster 1200C
Redrocker is an unknown quantity at this point
Angry HELP! Charging Problems with IRONHEAD
Guys I need so help before I pull whats left of my hair out! I have a 1977 Sportster 1000 with a new battery, Generator, & wiring. I went out riding the last fwe days, not far but enough to tune the carb. BUT TODAY I rode for a while stop to put gas in then mounted my piece cold hard steel motorcyle and the stupid battery was DEAD! I've checked everything I know how but can't find the gremlin! Any advise!!!!
Old 15th May 2009
Tin Man 2's Avatar
Tin Man 2 Tin Man 2 is offline
Sportster/Buell Model #2: XL1200, 2003
Other Motorcycle Model: Suzuki T250 Hustler
Other Motorcycle Year: 1971
Tin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond reputeTin Man 2 has a reputation beyond repute
....... I got tired of working on my Ironhead charging system, I put on a one wire Gen/Reg combo for about $150 and fixed it once and for all. Lost the Gen light but the Gen has Green diode light that comes on when its working. Not a resto piece but most dont notice with a quick look.
Old 15th May 2009
boilermaker's Avatar
boilermaker boilermaker is offline
Sportster/Buell Model: 81 sporty
boilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really niceboilermaker is just really nice
Didja polarize the generator
sesenta y ocho
Old 16th May 2009
ark's Avatar
ark ark is offline
Sportster/Buell Year: 1972
ark is an unknown quantity at this point
+1 on checking that, i bought my bike with a "charging issue" and got a real good price and thats all it turned out to be, quick 30 second fix
Old 16th May 2009
Work thru the Charging System Checkout Sticky post and report your results here.
Old 16th May 2009
Redrocker's Avatar
From what I understand the guy that put the new generator on polarized it. Can I polarize it again or how do I check to see. Also is there a way to check the regulator to see if it is bad? The regulator is the only part that I haven't replace YET!
Old 16th May 2009
IronHead78's Avatar
IronHead78 IronHead78 is offline
Sportster/Buell Year: 78
IronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura about
You should polarize it anytime the battery gets disconnected. I would try this then see what you have for voltage at the battery while running at about 2000rpm, should be about 13.5. (you should see the needle on your volt meter drop to around 12 when you let the bike idle back down to around 900 or so rpm, you won't start charging until 2000or more) I beleive most of the imformation you need is in the charging sticky.
Old 16th May 2009
78XLH_Newbie 78XLH_Newbie is offline
78XLH_Newbie is an unknown quantity at this point
I have a good generator 9.5 so im changing out my regulator...same issue
Old 16th May 2009
IronHead78's Avatar
If you are only getting 9.5 coming off the battery with a fully charged battery to start with, while running about 2000rpm. One or the other isn't working (reg. or gen). If your sure the generator is good, I would double check the wiring from the regulator to make sure it's connected right. If that checks out I myself would say the regulator is trash. Regulators are cheap compaired to a good generator.
Old 16th May 2009
I repeat ...
This is important!!! Do not leave out any steps. Do the whole thing. Everything you need is in that procedure.
