0 no rear brake light
Last Post: Screw Loose Dan
0 2016 48 Hesitating
0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
Old 27th March 2007
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Default Garmin Etrex problems on a pre '04
I have a Garmin Etrex-c and I installed it on my 1999 sportster last weekend. Unfortunately it won't stay on for long. I believe it is the vibrations that are causing it to intermittantley turn off. At first I thought it was the batterys shakin around in there so I wedged as much aluminum foil as I could in there to try and tighten them up. That didn't work so I then found that the screw that holds the handle bar clip on had worked loose, so I tightened that up. It still turns off when the revs get high and now it is so sensitive that if I flick the top of it, it turns off. I know I have seen a picture on here where somebody has an etrex mount to a pre '04 sportster and I was wondering if they have had the same problem.
Old 27th March 2007
rikava rikava is offline
rikava has disabled reputation
Call Garmin they have a very good customer service tell them your problem it just might be a simple fix
Old 27th March 2007
rokclmb's Avatar
rokclmb rokclmb is offline
rokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to allrokclmb is a name known to all
I carry mine in the front pocket of my Icon Mil-Spec vest. It makes it hard (technically probably impossible) to read while riding. I can check it while stopped. Just to prevent it from falling out I have a lanyard that is clipped to the zipper of the vest.
If you always do what you have always done; you will always be what you have always been.
"good spark + good air intake + good exhaust = horsepower + torque = fun!" Originally Posted by 883rnh
Old 27th March 2007
spatial.hd's Avatar
spatial.hd spatial.hd is offline
spatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the roughspatial.hd is a jewel in the rough
I think the problems Rascal had with his digital camera applies to your GPS as well. The Etrex wasn't made for lots of vibes. Garmin does make some models for use in vehicles that might handle the vibration better.
[URL="http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/3894"][IMG]http://xlforum.net/photopost/data/500/Spatial20070908d3.jpg[/IMG][/URL]
2006 XL 1200 Roadster Fire Red Pearl ---- [SIZE=1][URL="http://xlforum.net/forums/showthread.php?threadid=96044"]My dyno reports[/URL][/SIZE]
[SIZE=1]
[SIZE=4][SIZE=3][URL="http://www.freebase.com/view/guid/9202a8c04000641f8000000006fb5c28?domain=%2Fuser%2Fspatialed%2Fmotorcycle"]SHORT BUS ONE[/URL]
[/SIZE][/SIZE][/SIZE]Love every mile: city, country, mountain, highway...
Old 27th March 2007
Gone Gone is offline
I have the e-Trex legend C that I mount on my handelbars. I have never had a problem, but then I am rubber mounted.
Old 27th March 2007
snowman's Avatar
snowman snowman is offline
Yeah, no problem here either.....
I have a rubber mount!!!!!!!!!!!!!!!!!!!
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 27th March 2007
Rob Henderson's Avatar
Rob Henderson Rob Henderson is offline
Sportster/Buell Model: XL883/1200C
Sportster/Buell Year: 03
Sportster/Buell Model #2: FLSTF FATBOY
Sportster/Buell Year #2: 07
Rob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura aboutRob Henderson has a spectacular aura about
Rubber mounts are for sissys...LOLOLOL
Real men have bleeding kidneys...LOL
2003 XL883/1200C
Ceramic Bassani Sweepers, Forcewinder A/C, SE IGN, Wiseco 9.5.1, S&S Super E, Progressive 412's etc. etc, etc.
No More sporty......2007 FLSTF - FATBOY - I am a traitor!
