0 C.O.B.B run west
Last Post: pdavis5160
0 XL flywheel
Last Post: Dmac
Last Post: Heff
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: 72 Ironhead XLH
0 Shovelhead forum gone?
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: SKID LID
Last Post: 60weight
Last Post: Tucsonmax1
Old 3rd April 2005
larry p larry p is offline
larry p has disabled reputation
Default fork tube caps
does anyone know the torgue specifications for the fork caps on a 95 1200?
i cant find it in my book.......time for a new book.....or new eyes
thanks
lar
Old 3rd April 2005
xena's Avatar
xena xena is offline
Assistant Administrator
Look a little harder...It's gotta be in there if you've got a SM.
My 04' SM has a couple of pages that lists all the torque specs.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 3rd April 2005
i have a haynes service manual and its not in there, they tell you to look in chapter 1 but its not listed............my brain hurts.............
Old 3rd April 2005
flathead45's Avatar
Sportster/Buell Year: 86
Other Motorcycle Year: 1945
just get 'em tight , there is no real torque spec
I'd say about 35-40 pounds would be good if ya feel the need to fit a torque wrench on there
"lord of the Night Lite"
thank god for darwin ;)
Old 3rd April 2005
xena's Avatar
Larry, if it helps any, my 04' service manual says between 22-58 ft lbs which I'm sure it's ballpark for yours too. hth
Old 3rd April 2005
thanks guys and girls for your help, my brain feels better now........a little
Old 3rd April 2005
rottenralph's Avatar
I would just turn them till they are tight. They have orings on them and you dont want to destroy them. I would go closer to the 22 then the 58 if you ever want to remove them again.
Similar Threads
Progressive Fork Spring Installation DaleG Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 17 20th May 2016 00:33
Fork oil change. Chuck Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 50 25th October 2010 14:10
progressive part # ? Nightrider Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 7 8th April 2010 01:27
Fork tube nut!! Nightrider Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 18 4th May 2005 20:01
Fork Travel 04 1200R Mr Davo Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 3 30th January 2005 19:33
