0 Tank swap
Last Post: Grymy
0 Oil Hose replacement help.
Last Post: McQueen
Last Post: jcro61
0 2016 48 Hesitating
Last Post: andy_t
Last Post: JensWest
0 Primary Oil INSANITY!
0 Fuel Pump Problems
Last Post: Blues
0 Accelerator pump fuel sprays back out
Last Post: Cdyoung1985
0 FNG from OKC
Last Post: oreocat1
0 New From CA
Last Post: oreocat1
0 New in NM
Last Post: oreocat1
Closed Thread
Old 27th May 2009
melcheld's Avatar
melcheld melcheld is offline
melcheld has disabled reputation
Default Locaton of Engine Serial Number
Hey All,
Can someone tell me where the serial number is on the engine (2001)? I'm changing the registration on my bike to Minnesota (sigh) and they need the VIN off the frame neck AND the motor's serial. I searched but on found a lot of threads about serial numbers when switching out engines.
Thanks in advance.
Luke
Now if I have suspicion a felony's been committed, I can just walk right in here anytime I feel like it because I've got this badge, I got this gun, and I got the love of Jesus right here in my pretty, green eyes.
Old 27th May 2009
tensejed's Avatar
tensejed tensejed is offline
tensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to alltensejed is a name known to all
im thinking right side between cylinders just abone timing cover. ??
the females are fixing my old XL for fathers day . its a ford not a harley but its mine, MINE !!!
Old 27th May 2009
94Sporty's Avatar
94Sporty 94Sporty is offline
Sportster/Buell Model: 883 XL converted to 1200
94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough94Sporty is a jewel in the rough
The abbreviated VIN is located at the base of the cylinders on the left side above the primary. There is also an engine serial number but it is real hard to see. One location is on the bottom of the crankcase, in front of the oil pump. The hoses coming out of the oil pump are generally in the way. It is also stamped on the left crankcase somewhere inside the primary. The engine serial number can tell you what type of engine it is, what day it was built and where. Roger
Old 27th May 2009
melcheld's Avatar
Thanks much for the help. I'll have to get the bike up on the lift and see what I can see. I missed the # at the cylinder base.
Closed Thread
