0 Ran out of gas.
Last Post: Hellbent_4
Last Post: lehel
0 Best seat for long rides
Last Post: Diogenes415
0 First start question
Last Post: Jaime1840
0 need help with 68 XLH
0 2021 Iron Butt Rally
Last Post: riceburner
0 Valve Stem Seal ID
Last Post: BruceM
Last Post: 73HEAD
0 Tank and petcock identification
Last Post: Gravitas
0 Lurker from the SF Bay Area
0 Should I buy a Sportster??
0 cleaning your sporty
Last Post: Fifty150
Last Post: mac93
Old 7th April 2007
kenfm2000's Avatar
kenfm2000 kenfm2000 is offline
Sportster/Buell Model: xl1200n Sold
Sportster/Buell Model #2: FXDB Street Bob
kenfm2000 will become famous soon enoughkenfm2000 will become famous soon enoughkenfm2000 will become famous soon enoughkenfm2000 will become famous soon enoughkenfm2000 will become famous soon enoughkenfm2000 will become famous soon enoughkenfm2000 will become famous soon enough
Default Nightster Fork Springs
Well I had planned on trying to just add some spacers to the existing fork setup. I changed my mind after I jacked up the bike and pulled one of the caps off today. The stock spacer sticks out of the top of the fork tube almost 2". Wow that is way more preload than I thought it would be. I guess I will just wait until somebody finds a better solution. I think I can live with it the way it is for a while. I don't think I could possibly get a spacer in there for more preload enough with a second body helping me.
I did pull the spacer out and pulled the springs out far enough to verify it is definitely progressively wound.
Can anyone tell me what kind of stock preload other sports have compared to this approx 2+" preload?
Old 7th April 2007
MikeOK's Avatar
MikeOK MikeOK is offline
MikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really niceMikeOK is just really nice
Thanks for the report Ken. Did you happen to measure the stock spacer while it was out?
Old 7th April 2007
NoBoZoS's Avatar
NoBoZoS NoBoZoS is offline
Sportster/Buell Model: XL 883 Custom
NoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enoughNoBoZoS will become famous soon enough
I know the 03's have a 2" preload spacer.
Old 8th April 2007
kenfm2000's Avatar
Like an idiot I did not measure the spacer. It was however at least 10-12" long
Old 8th April 2007
johnnybgood's Avatar
johnnybgood johnnybgood is offline
Sportster/Buell Model #2: Honda CB700SC
Sportster/Buell Year #2: 1984
johnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nicejohnnybgood is just really nice
Your stock springs probably don't have a spacer. The Progressive springs were shorter than the stock springs on my "04. Stock springs, on my bike, stick out the top of the tube an inch or 2. I measured the difference between the 2 sets of springs (can't find my notes) and the stock springs were like 22 1/2" long compare to the Progressive's which were like 18 1/2" long, hence the need for spacers. Don't quote me on those numbers, but they're close.
John
Old 8th April 2007
dynamos2000's Avatar
dynamos2000 dynamos2000 is offline
dynamos2000 has disabled reputation
Anxious to hear the solution for the forks. I have the standard length Progressive springs and waiting for info before I tackle it. GOOD LUCK!
2007 Honda VFR800 Interceptor
SOLD: 2007 XL 1200N - SE slipons, 412 12.5 Shocks, NC Deflector shield, detachable backrest & rack, Corbin Hollywood solo seat
Old 8th April 2007
kenfm2000's Avatar
Thank you Johnnybgood.
Because you had 1-2" of spring sticking out of the top of the tubes of your 1200C I decided to go ahead with the spring replacement. I had ordered the standard springs for the sportster a couple weeks ago. I removed the old spacer the old spring installed the new spring reused the washer from the top of the old spring and then used the full 3" length of the spacers that came with the new spring. This gave me about 3/4" of the nes spacer sticking out of the top of the fork. I think this is a bout the right setup for me and my weight. I now have 3/4" of fork sag with my full weight on the bike.
Here is a link to a picture that shows the shorter stock spring and spacer next to the new spring. The progressive brand is a thicker coil material than the stock spring.
http://picasaweb.google.com/kenfm200...57016186509682
The ride is definitely better on small and large bumps. I just need to fine tune the 12" 418's that are on the back get a more comfortable seat and I should be all set.
Old 9th April 2007
Glad it worked out for you......they (Progressive springs) were too stiff for me.
Did you have fun getting the forks caps back on? I have read every little trick on the forum about getting them back on easily and found a trick of my own.................a helper!!
John
Old 9th April 2007
kenfm2000's Avatar
I marked the caps with a marker without the spacers in. Then i put the spacers back in. put the cap into the socket and pushed down on the top of the breaker bar. It took about 10 seconds to get each one lined up. So I guess it wasn't bad at all.
Old 9th April 2007
Must just be a problem for some of us little people.
John
