0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
7 Long Road Trip advice
Last Post: gunwish
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
0 79-83 dual disc fork spring length
Last Post: Reverend G
Old 31st May 2009
silvasilv silvasilv is offline
Sportster/Buell Year: 1989
Other Motorcycle Model: roadstar
silvasilv is on a distinguished roadsilvasilv is on a distinguished roadsilvasilv is on a distinguished road
Default chain tension... on a rigid
since i put my rigid struts, the chain on my 89 is now pretty damn loose
im bout to get myself a motion pro chain breaker/riveter so i can get it fixed up to ride, but im wondering now how tight the chain should be since my bike is rigid?
i know that when the bike has suspension the chain gets to be all sorts of different tensions while you are riding, but mine isnt going to flex anymore
so can some1 fill me in on what i should be lookin for tension wise on a rigid
Old 1st June 2009
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Cool
I would say that the adjustment would be similar to a chain on a bike with suspension, other than "the weight of one rider while adjusting".
1/4" deflection along the lower run between front and rear sprocket at the tightest point on the chain.
Old 2nd June 2009
Old 2nd June 2009
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I'd set it a little more loose, like around 1/2" to 3/4" at its tightest point.
Old 2nd June 2009
its about an inch or so right now its definitely pretty loose as i dont have a chain breaker/riveter yet...some one suggested i put on a tensioner so i dont get as much chain slap
anyone have any experience with this
http://www.lbvengchaintensioners.com...sportster.html
Old 2nd June 2009
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Yep, this is about perfect..the rest is too tight??
RTFS
Ride That F'N Sportster!!
Old 2nd June 2009
83XLX's Avatar
I bought one of those a few months ago, but it didn't work on my bike as designed - the roller touched my rear tire. It was a quality piece and would probably work well in a custom situation, though. I returned mine for a refund from a seller on eBay - he had a much cheaper price than anyone else. I can't really see the need for one on a rigid, though. Just take a couple of links out of your chain if it's at the end of the adjusters and isn't stretched & worn out.
Old 2nd June 2009
chain is brand new maybe 40 miles on it, the guy replaced it when i picked up bike from him, i guess ill get myself a chain tool and give her just a little slack
thanks a lot
Old 3rd June 2009
Cool
thanks a lot
Do you not have adjusters on the frame for the rear wheel? Increase the slack by loosening off, move wheel forward a bit, re-tighten...
Old 6th June 2009
King Herald King Herald is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 1990
Other Motorcycle Model: Yamaha 500 single
Other Motorcycle Year: 1982
King Herald is on a distinguished roadKing Herald is on a distinguished road
thanks a lot
Chain tool? You adjust it with the rear axle adjusters, not by cutting and shortening the chain.
Move the wheel back 1/8" and your chain will be tight.
If it was a new chain it will break in initially, then settle down like any chain does.
Twenty years from now you will be more disappointed by the things you didn't do than by the things you did!
