Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Lighting
0 Brake Squeek
Last Post: Tucsonmax1
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Not charging issue!
0 1977 Bright Blue
Last Post: robistro
Last Post: T^2
0 Mikuni HSR42
Last Post: Bulpitt
0 Where did it go?
Last Post: mwXL 2006
Last Post: BWP 5p
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
0 Sportster tour pak with Givi v47nn Tech Case
Last Post: FuriousGeorg
Last Post: church house mark
0 A Day in the Life...
0 Summer Bike Nights at Conshohocken Brewing!
Last Post: BILLETPROOF
Old 11th April 2007
Gone Gone is offline
Default Turn Signals Don't Blink
I Have An 2001 Xl883 Sportster With Stock Turn Signals And When My Bike Is Not Running, Just The Key On The Turn Signals Blink, But When I Run The Engine They Just Stay Illuminated, They Don't Blink Right Or Left Side, I Had A Run Brake Turnsignal Module In It Recently, But The Right Rear Run And Turn Signal Quit Working, The Right Front Would Work, But Not The Back, So I Unplugged It And Took It Out, And A Day Later I Started Having The Other Problem I Described In The Beginning, Does Anybody Have A Clue Whats Wrong With This ?? I Was Thinking The Turn Signal Self Canceler Module Is Bad ?? Any Help Would Be Appreciated, Thank You.... Bob..
Old 11th April 2007
Gold951's Avatar
Gold951 Gold951 is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Yamaha Virago XV 700
Other Motorcycle Year: 1987
Gold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enoughGold951 will become famous soon enough
Loose connection at the trun signal module.
Cliff Hipsher
'86 Porsche 951 Kalahari Metallic
'03 883 XLH
ICC USN (Ret.)
Old 12th April 2007
I Noticed The Rear Tire Rubbed The Right Rear Turn Signal Wires Under The Rear Fender, So I Fixed That Problem And Checked For Loose Connection And Any Other Messed Up Wires, And I Still Have The Same Problem !
Old 12th April 2007
trosga1's Avatar
trosga1 trosga1 is offline
Sportster/Buell Model: XL883L
Sportster/Buell Year: '05
Other Motorcycle Model: Heritage Softail Classic
Other Motorcycle Year: '11
trosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura abouttrosga1 has a spectacular aura about
I have the Kuryakn module on my bike and the module has a connection for the load equalizer, and a second connecter for a "blank" tail that basically just plugs in to seal off the connection ends. If the blank or the load equalizer are not seated all the way in the lights will either stay on solid, blink opposite to the turn, or flash without blinking.
2011 FLSTC with Vance and Hines True Duals, Arlen Ness A/C, Fuelpak, LED Turn Signals/Taillight.
Old 12th April 2007
I took my run stop turnsignal module out and just have it stock now, and my turn signals will not blink when i start my bike, they just stay illuminated, and dont blink, but they will blink when i have the engine off, and the key on, just for the heck of it i plugged my run turn stop module back in and the right rear light does not light up as a running light, and also doesnt blink, but my right front does blink, so i'm really stumped ?? i just want to put it back stock and have blinkers ...
Old 20th April 2007
I went ahead and went to Harley and paid $132.00 for the turn signal module, got it today, put it in and it fixed my problem, now my blinkers blink when I hit them, even when the engines running, stoked they work again..
Old 28th April 2015
Chiyonosake Chiyonosake is offline
Chiyonosake is an unknown quantity at this point
I am having an issue. I just got new turn signals for my bike after the originals were stolen. I hooked everything up and they light up if i turn on the blinker for that side but they dont blink and they don't work as running lights. any thoughts?
Old 29th April 2015
Did you buy HD blinkers? With regular dual-filament bulbs (1156)? Or are they aftermarket turn signals and/or with LED bulbs? And, until recently, only the front turn signals functioned as running lights - the rear signals only used the 1157 single-filament bulbs for signals only...
The stock Turn Signal Module (TSM) is designed to work with the 1157 (single) or 1156 (dual) bulbs which have a several amp draw of current that makes the TSM function...
If the replacement turn signals do not meet the original loads, the TSM will not blink...
__o~~o__
IXL2Relax
