Shotgun Porn
Last Post: GeoK
New in NM
Last Post: GeoK
4th April 2005
Posts: 284 Other Motorcycle Model: FLHTC Other Motorcycle Year: 2006
Removing Gear Shifter
Anyone have any tips on removing a gear shifter lever off a 2003 Sporty? After removing the pinch bolt, the lever doesn't slide off, and I'm afraid of marring the primary cover if I attempt to pry it off.
Thanks!
4th April 2005
Posts: 57 Sportster/Buell Model: XL883 Sportster/Buell Year: 2004
Be sure to completely remove the bolt from the lever and it should slide right off.
4th April 2005
Posts: 6,809 Sportster/Buell Model: 883/1200C Sportster/Buell Year: 2000 Other Motorcycle Model: Harley Heritage Other Motorcycle Year: 2007
Yep, pull the bolt completely out of the lever and then it should pull off fairly easily. IF not take a wad of rags and put it bwtween a flat blade and gently pry off.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
4th April 2005
Post no Avatars!
Posts: 3,723 Sportster/Buell Model: 1200S Sportster/Buell Year: 2001 Sportster/Buell Model #2: XLH-883D Sportster/Buell Year #2: 1988 Other Motorcycle Model: FXDXT Other Motorcycle Year: 2001
You can us a screw driver blade in the slot to
force it apart a little.
5th April 2005
Thanks for the tips! Will give it another try tomorrow after work.
5th April 2005
Posts: 2,654 Other Motorcycle Model: 2005 FXD Chopper Blue
Well first ya need to get a nice new hacksaw blade....then.......
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
5th April 2005
Luvs me an artsy chick...
Posts: 11,832 Sportster/Buell Model: 883>1200 XLH Sportster/Buell Year: 97
Plasma Cutter
~Chuck
Occam's Razor...
XLF Tuning Stickies
5th April 2005
Originally Posted by cantolina
Plasma Cutter
A lot less effort than a hacksaw but then ya have all the plasma burn to clean off
5th April 2005
Good point...hacksaw it is!
5th April 2005
I don't know about you, but if I were him, I wouldn't listen to us.
