Last Post: gpydeski
0 hi from anchorage AK
Last Post: Veeflys
0 Runs rough on highway.
0 The Multi-tool thread
0 Spectro STL 75W140
0 S.Y.B. Next to a waterfall.....
Last Post: Bama Lee XLC
0 WTF Happened
Last Post: 83XLX
0 Sportster in custom softail frame
0 Project Strociek
0 Mainshaft bearing
Last Post: Four Speed
Last Post: Smerch
0 2 into 1 exhaust build
0 900 dual carb front head
0 Floppy kickstand spring issue, 1991 model
5 Summer time heat
Last Post: ccmman
0 What is the best '70's Ironhead to restore
Last Post: Whitewalls
5 Why Are You Still Married?
Last Post: Flowerpunk
Old 4th June 2009
SuperTed's Avatar
SuperTed SuperTed is offline
Other Motorcycle Model: Fairlane 500
Other Motorcycle Year: 1964
SuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to all
Default When to replace brake pads?
The rear brake on my '01 1200C has been squeeking on and off for the past couple of months. I was wondering - how do you know when it's time to replace the pads? Is this my Sportster's way of telling me it's time?
The funny thing is that the brakes were serviced by a BMW guy in town before I purchased the bike from my father in law about a year and a half ago. Sounds like it's too soon for another service...
Old 4th June 2009
bigjnsa's Avatar
bigjnsa bigjnsa is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: BMW R1150R
bigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to allbigjnsa is a name known to all
How many miles and what is your riding style? Me, I replace the pads every 8k. I'm a heavy braker
aka - 'Bubba' of the Hells Beerguts MC
When we ask for advice, we are usually looking for an accomplice.
Marquis de la Grange (1639 - 1692)
[SIGPIC][/SIGPIC]
Old 4th June 2009
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Just because a bike has been serviced doesn't mean that the brake pads were changed. A year and a half ago they were probably fine. If they are squealing, it's most likely time to put new ones one. FSM spec is to change the brake pads when there is 1.02mm or less left on the pad itself (that's about .040 inches).
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 4th June 2009
SuperTed's Avatar
Thanks guys.
I ride mainly in-city on a daily basis, meaning I spend a lot of time doing the stop and go thing. Get up to 2nd gear, stop. Get up to 3rd gear, stop. If I'm lucky once or twice on the way to work, get up to 4th gear, stop.
How do you check the thickness of the pad? Can you just hold up a ruler to the pad while it's on the bike? I'm having trouble picturing everything back there. I want to do the work myself so I just want to be sure I'm doing it right!
Old 4th June 2009
MacAttack's Avatar
MacAttack MacAttack is offline
Sportster/Buell Model #2: Wouldn't that be nice!
Sportster/Buell Year #2: 1957
Other Motorcycle Model: Kawasaki Concours 14
Other Motorcycle Year: 2014
MacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really niceMacAttack is just really nice
Aim a flashlight in there, and look between the pad's backing plate and the disc. You'll see a smaller, thin bit of material in there. You can eyeball .04" OK; if in doubt, you can pull the pads out for a look, then measure with a caliper. If they're fine, and you don't like the squeaking, there are a couple products out there to stop it. One is a high-temp sticky stuff, the other is high-temp brake grease. Both form a tiny cushion between the caliper piston and the pad.
I have 16K on my originals; they look to be 1/2 gone, maybe more. I'm a gentle braker who rides mainly in the country.
Old 4th June 2009
wandrur's Avatar
wandrur wandrur is offline
Thx for the help, jackass
Sportster/Buell Model: XL 883 > SE 1200
Sportster/Buell Model #2: 1200 XLH
Sportster/Buell Year #2: 1999
wandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond reputewandrur has a reputation beyond repute
Nearly 17k on my originals. Front is maybe half gone; rear is maybe 60-70% gone. Still lots of miles left.
Old 4th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Pad Replacement
I can't quite bring myself to let the pads wear down to the 1/16" the book allows. Logic says it's okay. The little hairs on the back of my neck say otherwise. When they get much under 1/8th inch I replace them.
Old 4th June 2009
SuperTed's Avatar
Wow, if you guys are running 16-17k with only about half wear, I should definitely not be needing to replace my pads with 6k on them (if they were actually replaced when they were serviced - need to find that out).
MacAttack, who makes those "anti-squeak" products? If they form a cushion between the piston and the pad, does that mean I will need to do brake dissection to get the stuff in there? I have a service manual, but I've never done brake work before. It worries me a little just because of how important it is to stop!
Old 4th June 2009
argentcorvid argentcorvid is offline
Sportster/Buell Model: XL1200
Sportster/Buell Model #2: XB12XT (Ulysses Touring)
argentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enough
Don't be afraid to take the caliper off to look at the pads, it's pretty simple. It's the disassembly of the caliper itself that is pretty involved.
for the front, You just take out the mounting pin and bolt and slip the caliper off the disc. for the rear one, remove the pins, and push the caliper towards the wheel to push the piston in to the caliper, and it should slip off as well. the front pads stay in the caliper and the rear ones will stay by the disc, because there is a retaining clip.
you probably will want to lubricate the pins the caliper floats on anyway, so the pads don't end up looking like this. (I am just now having this problem)
Mods:Forcewinder XR, V&H Straightshots (wrapped), Keihin CV40 w/45 Pilot, 170 Main, N65C w/1 shim, SE ignition module, Front turn signals on the forks, Rear signals on license plate bracket, Drag bars w/~4" pullback risers, Xena's Speedometer mounting mod (Thread #3883), Mustang Seat, Removable windshield, Forward controls, Road King Rear shocks
Old 4th June 2009
xena's Avatar
xena xena is offline
Assistant Administrator
It's not necessary to remove the caliper to inspect or replace the pads.
Replaced mine last summer following the service manual. Was fairly
simple imo and I had never done them before.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
