0 Value of a Boattail?
0 z bars
Last Post: lucifer_mr2
Last Post: big andy
0 Brake Squeek
Last Post: Tucsonmax1
0 Won't rev past 1200
Last Post: Jowniofownio
0 Not charging issue!
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Mikuni HSR42
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Old 13th April 2007
nicksorg nicksorg is offline
Sportster/Buell Year: 1981
nicksorg has disabled reputation
Default 81 Sportster - Ignition Questions
My 81 has points ignition instead of the stock electronic ignition. Based on that, should I use a plug like the 4-5 for earlier sportsters vs. the 4R5? Also, should I be using a different coil than what came stock? Still troubleshooting a hesitation problem referenced in an earlier post.
Thanks.
Nick
Old 13th April 2007
chrishajer's Avatar
Sportster/Buell Year: 1988
The '71 - '78 XL with points called for a 4R plug, so I doubt using or not using an R plug is your problem.
The '71 - '78 used a 31609-65A coil, and when they went to electronic they went to a 31609-80 coil. I imagine the ohms were different there for electronic vs. points, but usually when you use the wrong ohm coil, it just burns up and fails, doesn't cause hesitation problems.
I don't really think either of these things are causing your problem, but I will look for your other thread...
--Chris
Old 13th April 2007
The one difference i am aware of is the spark plug gap: 030 for points, 040 for electronic.
Old 13th April 2007
RcRacer's Avatar
RcRacer RcRacer is offline
RcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura aboutRcRacer has a spectacular aura about
I'm sure if you or anyone addressed this but did you verify that your advance mechanism is working correctly?
