Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
Old 7th June 2009
harley75 harley75 is offline
Sportster/Buell Model: xl
harley75 is an unknown quantity at this point
Default drag pipes and ported heads
I have 1-3/4 drag pipes now with the heads being ported i was told to run open.But drag pipes are 5-7 thou in rpm now if i put 4' baffels in the pipe 6 inchs will this effect my jetting at all as far as low and mid power
Old 7th June 2009
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Put lollipops in the drag pipes for better bottom and mid range performance.
Old 7th June 2009
I heard about that and it gave info on how to make them but i forget where i seen it.Do they still go 6'' in the pipe
Old 7th June 2009
fdny37's Avatar
My pipes had a hole about 4" from the very end of the pipe or just in line with the slash cut. I think putting them that far in would make it very difficult to install and work with. I have slash cut pipes and the lollipop is at the beginning of the opening of the pipe. You might have to drill a hole on the backside of the pipe.
Old 7th June 2009
I have a hole right back from the slash cut that was in there i guess when they made the pipes.I'll have to find the info on making them
Old 7th June 2009
superwarden's Avatar
superwarden superwarden is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLC
Other Motorcycle Model: FXSTD
superwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of lightsuperwarden is a glorious beacon of light
You can just go buy a couple of eye bolts, that is what I did. Just be carefull about the angle and such as they may squeak a little bit at certain throttle...At least mine do and I can't seem to get it to quit...
Any date that is not on your tombstone is considered a lucky day.
Old 7th June 2009
turns out i had two in my box put them in on a 11-5:00 angle and tighten them up
Old 8th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Lolly Pops
Two cents. What makes the washer of the lolly pop effective is not the area or shape, but the fact that they have sharp edges. If you want to cause turbulent air flow, make it pass over a sharp edge, the sharper the better. Tears the hell out of laminar flow and really breaks up pressure waves.
That's what makes straight cut AR cones work so well. Sharp edge around the opening. Sharp edge facing away from the engine.
Just two cents tossed in.
